white exhaust smoke. couple questions and pictures...of smoke
Well i now notice that it only smokes quite badly when i bring up the revs and then let off, very quickly. I dont see how this would be coolant, but it could be possible.
To explain the pictures the smoke is after i just brought the rev's to 3k rpm, and held it there for about 5 seconds. I let off the gas, and it burbles a bit, i hear a wastegate noise, and then the smoke bellows out the exhaust tip.
As for the boost gauge pics, the one with a lower vacuum reading is at idle, than the vacuum dips down to an even -20 right at around 1500rpm.
Normal?
Just to note, my car still makes full boost, im running no cats on the car, and i notice a slight stumble at times.
If its not the turbos, that would be cool, but otherwise more money into the bottomless s4 money pit.
Normal?
pics.
<center><img src="http://pictureposter.audiworld.com/50830/pict0001.1.jpg"></center><p>
vacuum at idle.
<img src="http://pictureposter.audiworld.com/50830/pict0003.jpg">
vacuum at idle.
I wouldn't, but then again I wouldn't drill holes in my gas tank either. Something is obviously
wrong, get it into the hands of someone who knows what they are doing before you F it up more.
