why are people confused when tracking their car breaks it?
i don't know about you, but when i drive my car(s) at the track, i'm using them just as hard as i use my race cars. sometimes even harder if the sessions are 45-60 minutes. (sessions at SCCA races are only 20-30 minutes long)
that being the case, why do people seem confused when their car(s) fall apart? i expect 1-2 engine rebuilds a year. maybe a transmission. almost definetly the brake system (calipers, master cylinder, etc) every rubber suspension part. all at least once a year. brake rotors last maybe a month. etc...
if you track your car 1-2 times a month, this is what you should expect. probably even worse since your street car is not "set up" like a race car to widthstand the abuse...
fail after time. A commercial car is usually setup way below it's "limit" so as to insure longevity over most driving conditions. Modded cars are another story altogether ...
the new 996 with wet sump has poblems in this area. Owners have been advised not to use R compound rubber. The GT3 and 996 tt both use the older style block with dry sump(somewhat modified) to adddress this problem.
First road cars are designed to run much longer. That is why the S4 has 250HP vs 600. If tracked they should last much longer than race cars.
If tracked they will wear faster - tires, suspensions, brakes. But no, I do not expect to loose a tranny or rebuild an engine after 12 sessions.
If Audi cars can't take it, we will upgrade to Porsches and BMW's.
the suspension of a race car uses metal bushings, or at least stronger polyurathane or stronger rubber bushings. the brake pads, and tires are made to last longer. the motor mounts are stronger. there's extra cooling ducts all over. the fluids are changed after every day (or even every run) the fluids used are better, etc, etc, etc...
in fact... for SCCA type racing (the only kind i've actually participated in) i'd say 80% of the "mods" done to a car to make it a race car are mods to make it last longer, not mods to make it go faster.
given that. i'd expect a street car to have MORE problems falling apart at the track, rather then less.
you might not have engine problems (except for turbos) but all your other parts (transmission, clutch, suspension, brakes, bushings, etc...) are gonna fall apary FASTER on a street car.
if you track any street car, you're gonna pay MORE to keep it up, compared to a race car, rather then less.
