wierd no start problem: randomly my car will not start although I can smell it getting fuel and it'
crank over just with out ignition. I replaaced the ignition modules (correctly) and checked the conection a at the ecu and all related fuses. O evem disconexted that batery for a bit to clear all codes What would cause a no spark situation? I'm thinking I could have a bad ecu, I think this because I'm having this problem only randomly and not every time I try to start the car??
as it did throw a code many times granted it is new??? Also... Why would that give no ignition?
which turned out to be fuel (see post above). Many sensors will still let you start even if they're phut. If the Speed Sensor is not working it will NOT let you start.
Tony
Tony
snowchaser
13
08-17-2010 02:56 AM
stormy down
08-08-2008 03:38 AM
maggio
04-21-2008 05:32 AM
