Will 225/55/17 fit on the S4 without rubbing? Anyone using this size?
I have searched the forums and found some replies but no one using this size. I have a line on getting some winter tires that are in this size but from the sounds of it, they are going to be too tall to fit? Is this the case? Anyone using this size.
Should I pass?
Should I pass?
If your car is at stock height or lower, I'd doubt they'd fit under the wheel well. However, if you have had aftermarket stuff done like a coilover suspension where you can raise your car up during the winter, then I'm sure you'd be able to run that tire.
Sounds like they will be too tall to fit in the wheel wells. I might stick the tire against the current wheel/tire to see how much larger they are but it sounds iffy.
Sidewall/radius goes up by 0.9".
If you have over an inch above the tire to clear the suspension uprights on the inside of the tire (front and rear), give it a shot.
Looking at my car (stock radius) I kinda doubt it will fit.
dontcrash
Audi 100 / A6 (C4 Platform)
07-20-2005 01:31 PM
borden
03-31-2004 06:41 AM
Al Cantara
Audi allroad
05-20-2002 08:33 PM
