Will a PhatNoise fit in the stock CD changer location?
Tried a search, but it reported NO hits for phatnoise. Hmmm. But anyhow, can I simply slide out
my CD changer and slip in the phatnoise -with the
appropriate cable, of course?
thanks,
scot
thanks,
scot
Yeah, but I would reccomend just sliding the Phatnoise in and either velcroing
it down, or wedging it in there instead of screwing it in the CD changer screw holes. It will make it much easier to get it out in case you need to pull the plug in the future. It is a PITA to get the bracket out to get to the screws...which you will find out when you go to get the changer out. Many who had the older Phatnoise just velcroed it in there cause it was flat on the bottom. The new unit is angled, so I don't know if you'll be able to zelcro it, but you might. I just wedged a folded piece of paer in there to keep it secure.
Use the screws, not that hard...
<center><img src="http://pictureposter.audiworld.com/44443/pc280188.jpg"></center><p>I put one screw in each side. I don't trust velcro to hold it in under hard cornering or bumps.
Bruce
Bruce
It hardly moves with nothing at all. That thing is already snug in there. I just want to have easy
access to it in case they update the firmware again. I hate getting that bracket out of there to get to the screws.
