Will taking off my cats and replacing them with straight pipes throw any fault codes?...
Will it give me any sort of check engine light error? How much gain should I expect seeing im chipped with exhaust. Thanks.
Re: Will taking off my cats and replacing them with straight pipes throw any fault codes?...
I would guess yes and if you get caught by the law its a big fine...In MD we have 2 year emissions testing so at least in my state you would have to put them on for inspection. cat on/catoff
Here is another thought, done on a GMC Typhoon.
In Colorado, what they do is look underneath for a cat. If they see one, OK. If the emission test is within specs, no problem. Remove cat, cut open on TOP, remove guts, weld shut, remount. Weld is against floor pan. Seems like modern engine management systems control emissions quite well, and these days cats are political, more than engineering necessities. The Typhoon shows up with a slightly higher spike than with the cat, but well within specs. Been this way thru 4 test cycles. HOWEVER, it's a technical violation, so I'm not promoting it here. Just another option.
Unless...
You put in a circuit to fool the computer into thinking the cats are OK. Without the cats, the rear set of O2 sensors will oscillate just like the front set, centered around 0.45 volts (from 0-0.9 volts, give or take). This tells the computer the cat isn't doing it's job. Normally WITH the cat, the rear O2 sensor would oscillate around a lower voltage (say from 0-0.4) due to less oxygen. You can wire in a simple circuit to mimic this characteristic, and the computer will be happy. I think Mustang owners have down this with off-road y-pipes (and there is a place that sells the connector/circuit all ready to plug in).
Philhawtin
10-04-2013 05:15 AM
B5Davem
30v V6 Discussion
06-13-2007 07:49 PM
$teady$upreme
09-08-2003 07:04 PM
kam1200
06-06-2002 06:34 PM
