Will this tape suffice to protect my car during a track day? or, where can I get racers tape in DC?
AudiWorld Expert
<center><img src="http://multimedia.mmm.com/mws/mediawebserver.dyn?ffffff5myruf_3GfT3Gfff&PUrg cuXr3-"></center><p><ul><li><a href="http://products3.3m.com/catalog/us/en001/government/innovative_solutions/node_GSV75Q9WM5be/root_GS3RBW6QFVgv/vroot_31S2JJ7584ge/gvel_NQ8MLV63HWgl/theme_us_innovativesolutions_3_0/command_AbcPageHandler/output_html">Scotch® Safe-Relea
That's just masking tape...it would be like covering your front bumper with newspaper.
www.carcareonline.com carries racer's tape. If you have any speed shops near you, it's worth a try. For my own part, I'm just going to order it from larry...I don't feel like running around trying to find the stuff. He has a low adhesive variety as well. Not sure if it sticks well enough to be effective.
maybe you can use the blue (low adhesive) masking tape to create a protective layer and then apply duct tape over the masking tape. That should provide protection while allowing for easy removal. I haven't tried this personally - so I can't vouch for effectiveness.<ul><li><a href="http://www.carcareonline.com/detail.asp?product_id=20150">http://www.carcareonline.com/detail.asp?product_id=20150</a</li></ul>
For the whole front of the car you may consider a Bra. Takes up to 90 sec to load. Page 7.<ul><li><a href="http://www.colgancustom.com/support/appl_catalog/catalogsupp.pdf">http://www.colgancustom.com/support/appl_catalog/catalogsupp.pdf</a</li></ul>
There have been complaints that the adhesive is hard to clean up, which was the reason for the "low adhesive". Clues' suggestion is a good one...though it'll take a bit of time to execute. The only issue is rain...if it rains, it'll all peel right off. I find that the low adhesive masking tape just doesn't stick at all when exposed to moisture.
bassed-ndzmorezone5
03-05-2006 01:51 PM
MachtigAvant (v3.0)
07-11-2004 06:24 PM
Potomac-Greg
02-12-2004 12:43 PM
