Won't boost over 5psi
#11
Why don't you try this: delete the DTCs and drive only in stock mode. See if any too rich DTCs come back.
#14
In VAG-COM short hand this would be 001-08-032.
#15
OK, will do. Thanks for the info. Threw a cel last nite and have the same DTC codes, minus the intermittent message and of course only 5lbs boost.
2 Faults Found:
17537 - Fuel Trim; Bank 2 (Mult): System too Rich
P1129 - 35-00 - -
17535 - Fuel Trim; Bank 1 (Mult): System too Rich
P1127 - 35-00 - -
2 Faults Found:
P1129 - 35-00 - -
P1127 - 35-00 - -
#16
Here's the group 32 info from vag com. Can anyone decifer this? Thanks!!
Address 01: Engine (8D0 907 551 H)
18:11:43 Group 032: Lambda Control (Mixture Adaptation)
-0.9 % Adaptation (Idle) Bank 1 Sensor 1
-21.1 % Adaptation (Partial) Bank 1 Sensor 1
-1.5 % Adaptation (Idle) Bank 2 Sensor 1
-21.9 % Adaptation (Partial) Bank 2 Sensor 1
Sunday,11,July,2010,18:14:15:18150
VCDS Version: Release 10.6.0
Data version: 20100630
18:14:13 Group 032: Lambda Control (Mixture Adaptation)
Sunday,11,July,2010,18:18:18:18150
18:18:16 Group 032: Lambda Control (Mixture Adaptation)
-20.3 % Adaptation (Partial) Bank 1 Sensor 1
-20.3 % Adaptation (Partial) Bank 2 Sensor 1
#17
The block 032 is reporting that the engine is running very rich above idle speeds. The Partial adaptation of minus 20+ is trying to lean out the too rich mixture. Idle adaptation is within an acceptable range and is OK.
The question is why is the engine running ok at idle and too rich above idle speeds? I would guess the "fix" is going too be some expensive sensors. Do you have anyone that you can swap or trade for a test of the EGT sensors on your engine?
#18
EGTs are seriously expensive. They make O2 sensors look cheap.
If you are getting rich in both banks, I'd check the fuel system first starting with the fuel pressure regulator. You can get a mechanical fuel gage for way less than an O2 sensor even and be sure your fuel pressure is correct. If your fuel pressure regulator has failed causing this overly rich condition, changing EGTs won't do anything but empty your wallet.
It might be the EGTs, but it could just as easily be the FPR.
I think the next step here is to check fuel pressure at the rail with a mechanical gauge and diagnose the FPR.
:: www.ECStuning.com :: Now with EXTENDED Customer Service hours!! | FIND US ON FACEBOOK!!
Phone: 1.800.924.5172 - Sales: 8:30am to MIDNIGHT EST | Customer Service 8:30am - 8pm EST
Questions? PM us for a quick response! | Email: Pete@ecstuning.com
#19
Thanks Peter! I don't realy have another set of EGTs I can test with. I think I'll go with the FPR and guage from ECS. If that doesnt do it I'll go for the EGTs. I'll let everyone know the outcome.
#20
adjustment at idle as well as partial which it does not. I am betting on EGT sensors being needed.
