would 255/35 18's on some 8" rims fit without rubbing under the car???
and the 255/35's fit the 8 inch rims, yet that was the least width needed. check it out and tell me what you think...
http://www.nittotire.com/tire_nt555_sizes.asp
I guess the Nitto's have a wider range.
If the manufacturer says it'll fit, I don't see any reason to argue with that. As for rubbing, depending on the offset of your wheels, you will have to do some fender rolling to keep from rubbing.
is exactly the same (25"). You will definitely need to roll your front fenders to accomodate this tire size.
PS...we have a fender roller for rent (no wait).
on the fender roller. Is this size doable with SSR Comp's, and do you recommend using a heat gun when you roll the fenders??
...many have had this done. I'm not sure if you can run 255/35/18 tires without some amount of fender rolling.
This isn't a big deal as it's just adjusting the inner fender, not the part you see.
Also, I think most folks running 255/35/18 tires are between an ET35 and ET39 offset on their 18x8.5 wheels.
FWIW...
FWIW...
pearl2k
Audi Original "S" Cars
13
01-23-2007 12:17 PM
40valves
9
04-27-2006 11:59 AM
Guiche@S4
10
03-24-2004 11:43 AM
S4 Discombobulator
11-27-2001 06:58 PM
