Would something like this be sufficient for pressure testing my intake system?
<center><img src="http://content.sears.com/data/product_images/009/15239/00915239000-dlv.jpg"></center><p>I have this compressor, a more exact valve/gauge attached to it, and all of the part outlined in the AWE pressure testor PDF file. Will this work and, if so, how do I go about testing the system (I know its pretty straight-forward, but this is the first time I am going to be trying this, so I would like to know if there is anything I should know about before attempting it)? If this compressor isn't good enough, what should I pick up instead? Thanks in advance for your help.<ul><li><a href="http://www.sears.com/sr/javasr/product.do?BV_UseBVCookie=Yes&vertical=TOOL&am p;pid=00915239000">Craftsman 150 psi Compact Air Compressor</a></li></ul>
Also, make sure you tighten the living **** out of the 3" rubber clamp that goes where the accordian tube comes off. I thought I had it tight and it came off at about 10,000 MPH and sounded like a gunshot (plus it broke the little plastic bracket that hold the O2 sensor clips). Shouldn't need to go much past 10 psi. BTW, you can get all the stuff AWE advertises from Home Depot.
my question is whether the compressor I have is sufficient. Thanks.
100 or so psi in the tank and bring up the reg real slow. First time I did it I went all the way to 15 which from what I hear is too much. Be prepared for the car to make some weird gurgling noises as you do this as well.
