Would you put these tires on your car?.............
these are my old S03s. I've been driving around on my winter wheels and tires and one of them is bent so I picked up a set of stockers from ko pork for the summer and would like to just use the rest of these S03s. They got some wear on the inside when I didnt get alignment after lowering the car.
<img src="http://pictureposter.audiworld.com/33816/s03s_2.jpg">
<img src="http://pictureposter.audiworld.com/33816/s03s.jpg">
...so in your image, Tire on the Left would be a Right Front install and Tire on the Right would be a Left Front install.
...also, get an alignment and see how much Toe you're running. A lot of Toe will cuase that wear as much as the negative camber will.
I got an alignment when I put the winters on a while ago fall of 2003 I think. The winters look like they are fine and wearing out pretty evenly. Thanks guys.
There is a ledge on the shoulder of that tire. You don't get that kind of wear from a bad toe setting or extreme camber. Those tires look like they have been rubbing something. Flipping them to the opposite side won't fix the rubbing, and odds are you'll just chew up the other side of the tires too.
AudiWorld Expert
<img src="http://ctny.audiworld.com/mark/s4/wheels/dsc05819.jpg">
<img src="http://ctny.audiworld.com/mark/s4/wheels/dsc05820.jpg">
<img src="http://ctny.audiworld.com/mark/s4/wheels/dsc04219.jpg">
<img src="http://ctny.audiworld.com/mark/s4/wheels/dsc04218.jpg">
