X - 1 _ r a c e r: is this the battery you have?
#11
Yes, MJT...
You need the terminals if you are going to use a standard auto cable to connect it.
You need the metal jacket if you are going to install the battery in the front of the car (which I would do if you install a PC680 but maybe not if you go for the PC925). The reason is to protect the battery from heat.
I would say if you don't keep it in the front then heat is less of an issue and you can probably avoid the metal jacket.
Stephen
Stephen
