X-sauce with MBC only....should the MBC cause acceleration to be much rougher? b/c it is.
Spiking to 18psi and tapering to 14-15. When flooring it, the car hesitates for a second before really accelerating. Without the MBC it was instant mad boost (but it spiked to 21, which scared me).
Long story short, the hesitation is tolerable...just want to make sure it's normal with an MBC.
Furthermore, drivability will be just like before. My car was perfectly fine drivability-wise with MBC only on X chip, but I guess every car is different.
The red line is what you're doing now (after 5,500 RPM) and the blue is what you'll do if you go in parallel:
<img src="http://pictureposter.audiworld.com/69223/block_115-mbc_only-57d.jpg">
