For you data hogs. Some weight data on the Brembo 14" kit
AudiWorld Expert
All weights are per corner, front only.
Stock Setup:
Rotor: 21.8 lbs.
Entire setup (caliper, rotor, and pad): 36.65 lbs.
Alcon 6 pot kit:
Rotors (these were used a bit): 17.35 lbs
Entire kit (includes caliper, rotor, hat, adapter, pad): 28.10 lbs
Brembo 355mm kit:
Rotors (new): 16.8 lbs.
Entire kit (includes caliper, rotor, hat, adapter and pad): 27.95 lbs.
Disclaimer: The Alcon has a 6 pot caliper while the Brembo is 4 piston unit. The stock pads were used for 1.5-2K miles.
So, weight savings per corner over stock (the true comparitive) is 8.70 lbs for the Brembo and 8.55 lbs for the Alcon.
Stock Setup:
Rotor: 21.8 lbs.
Alcon 6 pot kit:
Brembo 355mm kit:
AudiWorld Expert
Maybe someone can post that data. I didn't have the AP and Stoptech setups...
Also, I'm trying to compare the 355 mm setups.
Anyone care to add to this data if they have available.
ThirdEye
07-31-2003 06:56 PM
triada
01-11-2003 07:35 AM
