You would think that the non-fouler O2 mod would be pretty easy, but........
#11
The walls of the antifouler do get very thin after drilling.
ImolaRocket: you are using 1 drilled antifouler and one unmodified one, right?
#13
and it made its connections again.
Didn't we hears something before about the Zoldman's not working with anti-foulers? I couldn't understand what the reason for that would be.
#14
Picked up an open 10lb box of rod for $5 or so at the welding shop last summer.
Didn't even bother switching out the cutting torch for a brazing tip ;P
<img src="http://tychl.txf.com/o2mod/notright.jpg">
Maybe mapp+oxy would do it for you?
#15
With...Bad, without...Good. The big question about the Zoldmans was whether they were a little bigger than stock. Supposedly they are the same size.
#16
It has a little lower melting point. Also hit AutoZone for another pack of non-foulers, and they had an older package of brass ones, instead of the pot-metal or whatever the newer ones are. I also got a pack of aluminum rod, with an even lower melting point. We'll see.
#17
enough to have any strength. Also make sure all your surfaces are clean and bright before starting.
#18
They are just slightly longer than stock and when I tried, I couldn't ever get them to thread cleanly. Now I see why you've killed so many sets of anti-foulers.
