Factory wheels - conservative offset
Does anybody think that the factory wheels are conservative in offset? I know it's common from the factory, but I think the car would sit better with some wheel spacers to bring the edge of the tire closer to the edge of the wheel well.
http://www.robcheng.com/s6bbs/
Link to my pics with aggressive offset. The wheels are 20x9 ET25, which pushes the wheels out 26mm relative to stock.
If my new wheels were 8.5" wide with ET25, then yes the difference would be 20.
I like the very simple wheel offset calculator found here:
http://www.1010tires.com/WheelOffsetCalculator.asp
Your math is right, and many will argue that large spacers are not a good thing. That have no experience to say one way or another. 20mm will push the wheels out 3/4" which should make a noticeable aesthetic difference.
If the spacer is a flat piece of metal and longer lug bolts are used, there shouldn't be a safety issue.
Spacers that are not designed specifically for the model of car should never be used. H&R and MTM both fit the hub perfectly and the both supply longer lugs. Spend the money for quality spacers and you will not have a problem.
