oddities
New 2016 S6.
Anyone parked the car, and when you came back in the morning found the moon roof cracked open? No one else in the house with keys but me.
I also found that some of my settings are lost (like entertainment volume during driver assist - parking assist).
Thanks
Lonwa
Thanks
Lonwa
New 2016 S6.
Thanks
Lonwa
Thanks
Lonwa
As to the settings reverting, I haven't had that one, but a large number of us have had an issue where the startup volume is 0, 12, or 14 randomly.
I've only had a couple of hours in the car - going to remedy that tomorrow with a country roads run up into the Sierra - but I have experienced that reset of audio volume a couple of times and been puzzled b/c I couldn't remember turning it down. Reassuring to hear I wasn't hallucinating it :-)
Whenever the car is turned off or the audio source is paused then resumed, the audio volume is set to a maximum of 12 to prevent a loud surprise. So if you have the volume set to 12 or less, it will not be changed. If it is set to 13 or higher, it will reduce to 12.
Except that's not what is happening with the 2016 cars.
Agree on the volume problem... More often than not my 2016 S6 volume seems to be set at zero when I start-up. Then sometimes it will be set where I left it (or maybe 12). Whatever the case, it isn't consistent and I can't find the pattern.
