Throttle Lag?
Hello, all. Recently came into possession of a '13 S6. Long story short, I was out driving tonight, in dynamic mode and manual shifting, and I noticed that there was a delay of as much as 2 seconds between pressing the accelerator and getting a response from the engine. At first I just assumed it was stupid amounts of turbo lag, but a quick google search didn't turn up a lot of other people mentioning it so now I'm curious.
Anyone have any ideas?
When I test drove a 2013 S6, I noticed some lag in the initial press of the accelerator. Not a lot of lag, but it was very obvious to me because I'm used to driving a naturally aspirated V8 BMW. I think it might have been 1 second of lag? It definitely was not 2 seconds, though.
There actually has been a lot of talk about this. However, I want to change your word "lag" to "hesitation". Lag would refer to the turbos spooling up which this isnt the effet of. This is more a delay in the pedal being pressed and the drive-by-wire sending the info to the computer.
I have played around with this the point where I can be stopped, stomp on the pedal very quickly down to the floor and release, and nothing will happen.
This is definitely more present when the transmission is in "D". There have been times where I press on the pedal from a dead stop trying to turn somewhere and the hesitation is almost so bad I almost get hit.
I have this already in as a complaint at AOA.
Sometimes it almost feels like the clutch isn't engaged yet. I would assume (hope) that the DSG keeps the clutch engaged even during off-throttle.
Any idea if this can eventually be addressed through a recall or software update?
The problem is it goes into the higher gears way too quickly(3rd by 15mph, 7th by 45mph). It has too many gears to decide what to downshift to when you actually do want to accelerate or pass someone. This is why when you are in "S" mode it keeps it in the lower gears longer and barely goes into 7th even on the highway.
Anyone that has an issue with this should call AOA and make a it known. Complaining on the forum doesnt really help any of us in the long run even though it creates good discussion.
Hard to say. Im sure if they get enough chatter about it they will have to look into it. The squeeky wheel gets the grease right?
This is a very real issue not your imagination.
I first heard about it in an S5 cab which a friend returned after 1800 miles due to being concerned he would get killed because the car pauses before going.
Over time you will retrain your foot on push the gas pedal far enough to get he car to move with jumping to warp speed. But when you drive your other car you'll be jackrabbit starting that one. LOL.
Perhaps a recode will come. It took 5 or more years for Audi to come clean with the RS6 DRC issue and try to fix that. (They failed, thus the KWV3 swap).
Mike
Mike
