Drivetrain Programming won't stay in DYNAMIC Mode
I've setup my own "Individual" Programming for the car
I've put the drivetrain setting to "Dynamic"
Whenever i restart the car, put it in drive, the car goes into normal (D) mode instead of Dynamic (SD)
If i go to the car settings, it shows that "Individual" is selected
If i then RE-SELECT "Individual" the car goes into Dynamic (SD) Mode
Am I missing something? What's the point of having this option to select the Dynamic mode if it doesn't actually leave the drivetrain in that mode?
The only solution is to pull back on the gear level which engages dynamic.
It works when you leave the car in "Dynamic" Mode....
It should also work in "Individual" mode shouldn't it?
Are you sure that it works in Dynamic mode? I've noticed this issue as well and I don't use Individual.
SMK_RS4
S6 (C7 Platform) Discussion
07-09-2013 07:28 AM
|skolnick
Audi Original "S" Cars
06-24-2008 04:55 PM
Horn (beep, beep)....mine doesn't work if the car is off - only when car is turned on - this normal?
roadrunner13
02-27-2002 03:03 PM
