S6/S7 Winter Tire/Wheel Question
I know there have been quite a few threads on winter tires/wheels for the S6/S7 but hoping for the group’s expertise on a few issues. My recently acquired 2016 S6 will be my first car where I intend to get dedicated winter tires (I have previously “made do” with Continental ExtremeContract DWS all-seasons on my cars). I’ve cross posted in the C7 S6 and S7 threads assuming that the answer is probably the same for both cars.
Thanks to all in advance.
- Is it worthwhile to invest in a full set of tires and wheels for the winter or just get a set of tires and switch them out on the OEM wheels twice a year? For background, I have the OEM 20” titanium finish wheels on the car.
- If the recommendation is just tires, how much of a process is it to get the tires swapped out twice a year? I would assume that the whole package would need to be re-aligned and balanced after each transfer? Any thoughts on approximate cost?
- If the recommendation is to get both wheels and tires, any recommendations on good (but not terribly expensive) wheels? TireRack seems to have an extensive selection in 19” wheels (my preferred size for winter tires) but I don’t know the first thing about wheels. I am also assuming that there is little benefit to the Audi recommended winter combo package (7.5x19 ET33 alloys, 235/45 R19 Continental ContiWinterContacts) at $3200? Seems overpriced but thought I would ask if anyone knows of any unique benefits with this package.
- What equipment would you recommend to change out the tires/wheels on my own if I go with a full set of winter tires/wheels? I would assume it can be done with the standard tire change kit that comes with the car but I am sure there is a better way. I am also concerned about over-torqueing the bolts with just the standard tire iron.
- Finally, with respect to tires, TireRack and the threads seems split on Pirelli Sottozero 3 or Bridgestone Blizzaks. Any recent experience from the NE region from this past winter that might sway me one way or the other?
I'd strongly suggest a dedicated set of wheels and tires. Having tires unmounted, remounted, and the wheels rebalanced twice a year would be expensive, tedious, and possibly damage the tires long term.
- A good quality, low profile jack from an auto supply store. By "low profile", I mean a jack that will fit under the body kit these S cars come with. REMEMBER TO SET TIRE CHANGE MODE IN THE MMI (Car Systems->Checks and Maintenance) so the air suspension doesn't get confused when you lift the car.
- A 1/2", 17mm, nylon coated socket so you won't scratch your wheels. I use the socket from .
- A good quality torque wrench, nuts should be torqued to 90 lb/feet.
- A 1/2" breaker bar to get the wheel nuts loosened.
- These from Amazon.
- (Optional) These wheel installation studs from Science of Speed.
A few comments since it sounds as if you haven't changed wheels on your Audi before:
- As a German car, the Audis use lug bolts rather than lug nuts. Once you remove the bolts the wheels will fall off. Be prepared for this.
- Loosen the bolts with the breaker bar and 17mm nylon socket while the car is on the ground.USE THE JACK PUCKS. There are semicylindrical recesses at the jack points of the car these pucks fit into. If you try to jack the car with a normal jack without using these pucks you will DAMAGE THE CAR. (Ask me how I know this.) Of course the Audi jack will work on its own but it's a weedy little thing only suitable for emergency roadside use. IMO.
- The Science of Speed wheel installation studs will make putting the wheels on much easier. You just hand screw two of them into two non-adjacent holes in the hub, and they locate and hold the wheel as you slip it on. Screw in the remaining three wheel bolts, remove the installation studs, then screw in the remaining two wheel bolts.
- Medium-tighten the nuts while the car is in the air, then drop the car to the ground and use the torque wrench for the final tightening.
Here’s a post I did a couple of years ago. Have loved the setup ever since. I’ve used these winter wheels/tires in Wisconsin and in Denver. The roads in Colorado are WAY worse in the winter than anywhere I’ve ever lived (b/c of the temperature swings, lack of using real salt and bare minimum snow plowing). Everyone should have all wheel drive and snow tires here! I have scratched my winter wheels a bunch and am glad to have them vs scratching up my OEM wheels.
https://www.audiworld.com/forums/s7-...tires-2900619/
SpeedracerIndy
10-29-2008 09:31 AM
Pat
Wheels & Tires Discussion
04-17-2002 01:05 PM
