Brake pad light reset
Old 07-23-2010, 07:02 PM
Comoman's Avatar
Default Brake pad light reset
Hi all,
I have just replaced all brakes and sensors with genuine Audi parts. However the brake pad warning light is still on. I assumed it would self-extinguish but no luck.
Has anyone got an idea how to reset? What are the required codes?
Cheers
Old 07-23-2010, 07:43 PM
AudiWorld Expert
Reggie's Avatar
Originally Posted by Comoman
Hi all,
Cheers
You must have a open in the circuits - check your electrical contacts at the wiring off the pads. Also check your fluid level in the brake reservoir
Old 07-23-2010, 11:33 PM
Comoman's Avatar
OK thanks - so you don't have to do anything via the VAG at all? No reset or anything?
Old 07-24-2010, 12:21 AM
Comoman's Avatar
Sorry can't find how to edit my previous post:
Have checked fluid level all ok - will try to check for the wiring next.
Old 07-24-2010, 02:28 AM
DUTCH VanAtlanta's Avatar
Check to be sure that you plugged all the wear sensors in properly.
Old 07-24-2010, 03:53 AM
The Traveler's Avatar
You may also want to try getting a very, very small screwdriver, a paperclip, and some electrical cleaner to clean up the connections. I made blank plug-ins for mine, but the light still wouldn't go off. Turned out the connections were so corroded there just wasn't contact.
Old 07-24-2010, 07:28 AM
Comoman's Avatar
Thanks everyone.
So to confirm - I have to do nothing with the VAG. The light should go out by itself with new sensors. Is this right?
I'll take a look at the connections....
Old 07-24-2010, 11:09 AM
Thanks everyone.
Jawohl!
Old 07-26-2010, 03:26 PM
Comoman's Avatar
OK thanks. Tried everything - even got the old sensors, cut and twisted the 2 wires to short them out and plugged them in. The brake warning still comes on and soon as I engage a gear - not when I press the brake pedal.
I guess I have to go to Audi and get the computer plugged in - very frustrating.
Old 07-26-2010, 03:46 PM
You have a break in at least one of the wires. The brake pad light comes on when one of the wires is broken and you have an open circuit.
When I did my pads, I forgot to plug in one of the sensors. As a result, I had the brake pad light on. VAG gave no indication of any problem. I just had to find the open circuit, which in my case, was an unplugged sensor.
I don't think the Audi computer will show you much, if anything.
Quick Reply: Brake pad light reset
