Q5 Lane Change Assist fault
My driver lane change blind spot says system fault when I try and hit the button on the A-pillar. Scanned and got the following fault - not sure what to do here:
1 Fault Found:
730117 – Control Module 2 for Lane-Change Assist
C1115 F0 (009) – Automatic Calibration Not Possible
Confirmed – Tested Since Memory Clear
1 Fault Found:
I did find the calibration procedure if the module is replaced. I'm thinking $$$ for Audi to calibrate the system.
https://workshop-manuals.com/audi/a4...nit_j769/j770/
Control module 2 for the Q5 would be 8T0 907 566 B - correct?
Which would be the drivers side rear?
If I buy this and plug/play - would that at least rid the fault but then still ask me to see dealer for calibration? Used ones on ebay for $100.... maybe worth a shot.
Did you ever figure this out? My wifes Q5 just started giving this error.
Never bought a replacement unit. However I did look at the procedure (adaptations) to install a replacement and they're quite extensive. In other words it's not "plug and play" and can only be done at a dealership.
I saw that - however I figured I could at least install the new (used - good) unit myself and have the dealership calibrate.... then I'm only paying labor. Which I can't imagine would be more than an hour - but I guess I should call and ask.
