Another Tire Choice Question
Sorry I know this has been beat to death but, Goodyear RF are done what are you folks replacing with.
Looks as though their are not allot of options. I need a all-weather tire. Trying to stay away from RF if I can.
That stinks because I had good luck with my run flat Goodyear tires.
My 2017 Q7 had run flats and I replaced it with a 2019 and really didn't look at the tires and now realize - no run flats..........and I'm not liking it.
It will be interesting to see what's available.
I am considering getting these once my RFTs are done. They are slightly narrower but should fit the 20" wheels. I was thinking of going wider at 295/45 R20 but that is slightly off spec and there are fewer choices and higher prices in that size vs 275/45 R20. Right now there is a $100 rebate when buying 4 of these, which makes it a little over $1K + tax + installation cost.
I had a LONG conversation with TireRack about this. And after doing tons of research I have recommended this to multiple folks on this forum and all have come back and thanked me so far.
TireRack was there to convince me to go UHP (ultra high performance) all season over Grand Touring (more noise and ride oriented)...
I personally have this setup and it is what I have recommended. Continental DWS 06 in 275/45/20. The car rides incredible and it makes a world of difference. Either way, if you are not happy with runflat, then going 275/45/20 gives you 15X more options than the factory 285/45/20 and they are less expensive. You will not notice a difference from the outside, all you will do is bring an already fun to drive car to the next level!
Hope this helps!
Hope this helps!
Hope this helps!
Hope this helps!
It would be on my tire list.
Thanks for recommendation.
Honestly I have no idea... I would say something along the lines of 36-38 all around. I can check when I remember and am home.
