I'm so fed up with Auto Start
Hi Guys,
Sorry for the upcoming rant.
I am so fed up and so sick of the Auto Start that I'm starting to lose it.
Why did Audi not allow users to select what mode that want and keep it that way.
I'm new to coding, I have not coded anything myself, but I think that I can figure it out.
Can someone point me in the right direction on which coder to buy? Or if anyone has a recommendation for a shop in Toronto area that does coding for these cars.
Also, my car did not come with Audi Driver's Assist Package - NO ACC, Lane Keep, and all that jazz.
However, when reverse parking, I do get warning from the car that there is cross traffic coming.
Also, in certain situations, the car will slam on the brakes. Like when backing up and approaching an object.
Can this be coded out as well?
Also, I've heard that people are very cautious about the warranty. If I code some things out, should my warranty still be active?
I feel that in another month, I'm going to wear out the Auto Start button.
Thanks in advance
Thanks in advance
Hello fellow Torontonian Buy a Carista Dongle on amazon for $26 and disable the auto start/stop (plus activate / de-activate some other goodies as well within the 1 month trial).
Re your other gripe, in 2.5+ years of owning the car I have had the car abruptly stop 3 or 4 times total due to the sensors seeing something that was not there. I believe you can disable it via MMI or at least make it less sensitive.
Good luck!
Good luck!
Hi Guys,
Thanks in advance
Thanks in advance
For the cross-traffic, it's a pita and I need to disable it (by turning off the rear camera) every time I back out my driveway.
Good luck!
Good luck!
this one?
is this what you did to yours?
which part of TO?
also, what about warranty? Will coding void anything?
for the last 2months of ownership, my car slammed on the brakes at least 5 times. But I reverse park all the time
Turning off stability control will disable rear cross-traffic alert. I do that every time I back into my garage. To turn off, hold down the ESC button for 5 seconds.
https://obdeleven.com/en/
Good luck!
Good luck!
Question on the Carissa - can you just deactivate the Start/Stop or so you have to ‘trick’ it into not activating like with the OBDEleven?
There are a ton of threads on both of these options if you do a search. Talks about a lot of the programming you can do (mostly super easy) and people’s experience and opinions about potential warranty effects.
Warranty is arguable...but Audi has to show
that you buggered something. Simply disabling auto stop/start can’t void warranty..in fact it will increase life of starter (unless audi put in a coaxial 40hp starter generator in which case it’s probably irrelevant) but for argument sake suppose an overheat situation won’t stop the engine if the auto stop/start has been coded out...something like that could void your warranty if the engine had other issues that your coding affected.
https://www.ecstuning.com/b-obdeleve...4871obd02~obd/
