Q5/SQ5 MKII Discussion Discussion forum for the Second Generation Audi Q5 SUV
How to reset "Inspection Due" indicator?
Old 02-26-2021, 06:24 AM
JonnyRotten's Avatar
Default How to reset "Inspection Due" indicator?
Now I've searched the forum and haven't been able to find a definitive answer as to how the "Inspection Due" warning indicator can be reset.
It's obvious that one way is to take your vehicle to the dealership and have them do it but I'm looking for a DIY method.
I've read something online about turning on the ignition and pressing the gas pedal three times and then starting your car for the 2018's but it's not clear if that works on the 2019's.
I saw something about using the OBDEleven but I'd like to know if there's any other options so I'm hoping someone is the subject matter expert and can provide the answer.
Old 02-26-2021, 07:19 AM
BarneyM's Avatar
OBDEleven, Ross-Tech or the dealer are your choices for Inspection reset.
JonnyRotten (02-26-2021)
Old 03-10-2022, 11:58 AM
Corbo35's Avatar
Default Inspection Due 2016 A4
Hi all
was able to reset the mileage and days for next inspection. Question is, how do i stop tbe notification popping up on the dash every time i turn the car on and switch it off? Using OBD11. Many thanks in advance
Old 03-10-2022, 09:46 PM
Wesleyh96's Avatar
I believe it's in the app section or the service section where you can reset inspection
Old 03-10-2022, 10:18 PM
Corbo35's Avatar
Thanks for the reply. Managed to get it done after a few select word muttered to myself lol someone had changed the inspection due miles to 400miles and the days to 0. All set up again and notification away. Thanks again
Old 03-11-2022, 02:46 PM
aclass's Avatar
Corbo, what did you use to reset it?
Old 03-11-2022, 03:11 PM
Corbo35's Avatar
I used OBDeleven to reset the notification
aclass (03-12-2022)
Old 03-11-2022, 06:01 PM
rdgrimes's Avatar
I used Carista to reset my '18 SQ5. There was a reset for inspection and one for oil change.
aclass (03-12-2022)
Old 12-14-2023, 09:13 AM
spindlewood's Avatar
I wanted to reset the service due reminder on my SQ5 and found all the posts recommending to use the OBDeleven app. I always prefer to use a free method whenever possible. The following works:
Reset Service Due Reminder
Dashboard (17)
Adaptation > FIX: Distance covered since last mileage-dependent inspection
> new value 0
Adaptation > FIX: Time since last time-dependent inspection
> new value 0
jaims (12-14-2023)
Old 12-17-2023, 07:18 AM
Rondog54's Avatar
Dashboard (17)
Adaptation > ??????????????????? Could you explain this in english for us "Old" Guys?? I certainly can't make heads or tails of this.
Quick Reply: How to reset "Inspection Due" indicator?
