Mine was just in the garage yesterday over this. Apparently if it happens first thing on start up, its a processor issue and is acceptable by Audi as it sorts itself out after a few mins. But mine was mid drive. They took it in an apparently moisture was in where the lens is. The opened it up and done something. But they also noted there is an update or something due which i have to drop it in for a day to update. Hopefully its fixed. It hasnt popped on today anyway.
Thanks, I think this could be it, I actually had a look at the sensor late yesterday evening and could see a bit of discolouration / moisture on the inside of the glass where the radar sensor is. Not sure how it would have gotten in there, but will probably have to let Audi look at it, I can see a new radar sensor is quite expensive so don’t want to do further damage.
Yea i wouldnt be going near sensors. One wrong move and this could be extremely costly. Iv been out and about a few times today in the pissing rain and it hasnt come up once. So hopefully its sorted out. Id imagine its a similar issue.
thanks, will try to pry it open and undo any clips I find.. I said this to Audi about cleaning the window and running the free software update but the service area said “they have to run a diagnostic for my safety”
I'm in bed right now but if you give me ~12 hours I can have the full Audi guide sent to you for prying the cover off, failing that there are 2 clips on either side on the ends and 2 more clips where the cover meets the headliner symmetrically spaced out a quarter of the way through that need to be undone, preferably with a plastic pry tool.
