I'm in real trouble 😵💫 and hope that someone here can help me.
I wanted to update my firmware on my car, in order to update the maps for the navigation.
I managed to install MIB and got the green screen working. I then proceeded to patch the firmware and here is where it went wrong. Apparently the SD card I used was corrupted, and caused a lot of damage to the MMI.
As of now the MMI boots into sdcard media screen and posts no readable media on source, and after 1 minute it reboots, this goes on forever. I've posted images of the screen now and the firmware version I had before it went bad.
As of now, I've installed UART on the unit and have access to it. However I can't boot into emergency.
I've added a couple of logs, if that helps.
I made a backup of the firmware before patching, so I have this, but from here on, I have no idea what to do.
I've found a similar problem on this forum, but the post is from 2021 and the user doesn't seem to be active anymore 😓
