12v Inside Steering Wheel
Old 06-22-2024, 02:14 PM
nighthawk5263's Avatar
Default 12v Inside Steering Wheel
Hello,
I am currently in the process of installing a new wheel that has shift lights on it, and they need to be connected to a wire with 12v power only when the car is on, and then they also need grounded obviously. My question is if it would be safe to tap into one of the wires that connects to the plug on the back of the airbag. I couldn’t find a diagram for what each wire is for, so I suppose I could just use a multimeter to find one with a stable 12v, and then connect to that, I was just wondering if it would be safe to do so.
Old 06-22-2024, 02:44 PM
SMac770's Avatar
Received 2,040 Likes on 1,736 Posts
red on 8 to brown on 10 should measure 12v
Old 06-22-2024, 03:21 PM
Which way are the pins counted for this specific plug? Left to right or right to left? And top to bottom or bottom to top?
Old 06-22-2024, 04:35 PM
SMac770's Avatar
Pin numbers are always stamped on the connectors. Don't know the B9 airbag harness connector offhand. Or look for the red and brown wires.
Old 06-25-2024, 11:06 AM
I was able to locate the correct wires. Are you saying that I could use either of these for 12v power? Or are you saying that positive on red and negative on brown would work for 12v?
Old 06-25-2024, 11:29 AM
SMac770's Avatar
"red to brown", that's not "red or brown". Get out a meter and measure to validate. 12v is on red, ground is on brown.
Old 06-25-2024, 01:09 PM
After testing those two pins on the steering wheel mount, it is a steady 12v however,
it seems like the power from those two pins is always on. Maybe we aren’t waiting long enough for it to shut off after turning the ignition off? Or maybe the yellow airbag clip not being plugged in makes a difference?
Old 06-25-2024, 02:46 PM
Seems that the power is constantly on after waiting for a while and retesting, I don’t know that it’ll be a problem once the yellow plug on the airbag itself is plugged in, but we will see.
Old 06-25-2024, 04:22 PM
Seems to be working good now, thank you so much for your help! I’ll post the wheel shortly.
Old 06-25-2024, 07:12 PM
sammk1234's Avatar
Anxiously checking my mailbox every couple of hours to see if the new wheel arrived...
Quick Reply: 12v Inside Steering Wheel
