Control Module Incorrectly Coded
Reaching out for some help on properly coding modules if available
tried many workaround options from Ross wiki still showing many modules incorrectly Coded any tips would help....2004 Audi A8 4.2l D3
Thank you..
Wednesday,05,June,2024,17:32:36:18900
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 10 x64
VCDS Version: 24.5.0.0 (x64) HEX-V2 CB: 0.4643.4
Data version: 20240429 DS355.0
www.Ross-Tech.com
VIN: WAUML44E14N022231 License Plate:
Chassis Type: 4E (4E0)
Scan: 01 02 03 05 06 07 08 09 0E 13 15 16 17 19 1E 25 28 34 36 37
38 42 46 47 4E 4F 52 53 55 56 57 5E 61 62 72 75 76
VIN: WAUML44E14N022231 Mileage: 245750km-152701miles
00-Steering Angle Sensor -- Status: OK 0000
01-Engine -- Status: Malfunction 0010
02-Auto Trans -- Status: Malfunction 0010
03-ABS Brakes -- Status: Malfunction 0010
05-Acc/Start Auth. -- Status: Malfunction 0010
06-Seat Mem. Pass -- Status: OK 0000
07-Control Head -- Status: Malfunction 0010
08-Auto HVAC -- Status: Malfunction 0010
09-Cent. Elect. -- Status: OK 0000
0E-Media Player 1 -- Status: OK 0000
13-Auto Dist. Reg -- Status: Cannot be reached 1100
15-Airbags -- Status: Malfunction 0010
16-Steering wheel -- Status: OK 0000
17-Instruments -- Status: OK 0000
19-CAN Gateway -- Status: Malfunction 0010
1E-Media Player 2 -- Status: Cannot be reached 1100
25-Immobilizer -- Status: Malfunction 0010
28-HVAC, Rear -- Status: Cannot be reached 1100
34-Level Control -- Status: Not registered 0011
36-Seat Mem. Drvr -- Status: OK 0000
37-Navigation -- Status: Malfunction 0010
38-Roof Electronics -- Status: Malfunction 0010
42-Door Elect, Driver -- Status: OK 0000
46-Central Conv. -- Status: Malfunction 0010
47-Sound System -- Status: Malfunction 0010
4E-Ctrl Head RR -- Status: Cannot be reached 1100
4F-Centr. Electr. II -- Status: Malfunction 0010
52-Door Elect, Pass. -- Status: Malfunction 0010
53-Parking Brake -- Status: Malfunction 0010
55-Headlight Range -- Status: OK 0000
56-Radio -- Status: Cannot be reached 1100
57-TV Tuner -- Status: Cannot be reached 1100
5E-Ctrl Head LR -- Status: Cannot be reached 1100
61-Battery Regul. -- Status: Malfunction 0010
62-Door, Rear Left -- Status: OK 0000
72-Door, Rear Right -- Status: Malfunction 0010
75-Telematics -- Status: Malfunction 0010
76-Park Assist -- Status: Not registered 0011
Address 01: Engine Labels: 077-910-560-BFM.clb
Part No SW: 4E0 910 560 A HW: 4E0 907 560
Component: 4.2L V8/5V G 0070
Revision: 00000000 Serial number: AUX3Z0D2535957
Coding: 0007773
Shop #: WSC 02313 067 57207
VCID: 1F1BEE580BB941B24E9-804A
VINID: 9D195D7041150447800820830498E11D23
5 Faults Found:
18284 - Valve for Torque Support Mount
P1876 - 004 - Open Circuit
16405 - Bank 2: Camshaft A (Intake)
P0021 - 002 - Retard Setpoint not Reached (Over-Advanced) - Intermittent - MIL ON
17536 - Fuel Trim; Bank 1 (Mult)
P1128 - 001 - System too Lean - MIL ON
17538 - Fuel Trim; Bank 2 (Mult)
P1130 - 001 - System too Lean - MIL ON
16487 - Mass Air Flow Sensor (G70)
P0103 - 008 - Signal too High - Intermittent - MIL ON
Readiness: 0000 1001
Address 02: Auto Trans Labels: 09E-927-156.lbl
Part No SW: 4E0 910 156 E HW: 09E 927 156 A
Component: AG6 09E 4,2L5V USA 0110
Revision: 00000001 Serial number: 0031749
Coding: 0000002
Shop #: WSC 02313 785 00200
VCID: 2411E1B422DF626A13B-8070
1 Fault Found:
18265 - Load Signal
P1857 - 000 - Error Message from ECU - Intermittent
Freeze Frame:
RPM: 1728 /min
RPM: 1312 /min
RPM: 1504 /min
(no units): 5.0
(no units): 59.0
Temperature: 91.0°C
T.B. Angle: 19.2°
Voltage: 11.20 V
Address 03: ABS Brakes Labels: 4E0-910-517.clb
Part No SW: 4E0 910 517 B HW: 4E0 614 517 N
Component: ESP 5.7 allrad H44 0500
Coding: 0007597
Shop #: WSC 02313 000 00000
VCID: 221DE7AC38CB6C5A617-8076
2 Faults Found:
18265 - Load Signal
00283 - ABS Wheel Speed Sensor; Front Left (G47)
012 - Electrical Fault in Circuit
Address 05: Acc/Start Auth. Labels: 4E0-910-131.lbl
Part No SW: 4E0 910 131 HW: 4E0 909 131 A
Component: FBS AUDID3 H03 0140
Revision: 01403903 Serial number: AUX3Z0D2535957
Coding: 0263168
Shop #: WSC 02311 785 00200
VCID: 58E985442E17F68A4F3-800C
Subsystem 1 - Part No: 4E0 905 852 D
Component: ELV 1834
1 Fault Found:
00668 - Supply Voltage Terminal 30
002 - Lower Limit Exceeded - Intermittent
Freeze Frame:
Fault Status: 00100010
Fault Priority: 2
Fault Frequency: 7
Reset counter: 88
Mileage: 244272 km
Time Indication: 0
Date: 2024.03.22
Time: 14:38:26
Address 06: Seat Mem. Pass Labels: None
Part No SW: 4E0 910 760 C HW: 4E0 959 760
Component: Sitzmemory BFS H07 0060
Revision: 00000000 Serial number: 5DS 008 795-03
Coding: 3940448
Shop #: WSC 00000 785 00200
VCID: 2313E2A827D165526A1-8076
No fault code found.
Address 07: Control Head Labels: 4E0-910-7xx-07.clb
Part No SW: 4E0 910 731 N HW: 4E0 035 729
Component: Interfacebox H43 3360
Revision: 00000000 Serial number: 346BL047510539
Coding: 0000003
Shop #: WSC 12345 111 45725
VCID: 2C0109944A0FAA2ADBB-8078
Subsystem 1 - Part No: 4E0 910 611
Component: E0380 BedienteilH01 0040
Subsystem 2 - Serial number: 00000000023587
Subsystem 3 - Serial number: 0131.10.060000000100010029ÿ
Subsystem 4 - Serial number: 010029ÿ
2 Faults Found:
02084 - Component Protection
005 - No or Incorrect Basic Setting / Adaptation
Freeze Frame:
Fault Status: 01100101
Fault Priority: 5
Fault Frequency: 1
Reset counter: 159
Mileage: 178306 km
Time Indication: 0
Date: 2003.10.08
Time: 00:00:10
02257 - Remote Control Receiver
014 - Defective
Freeze Frame:
Fault Status: 01101110
Fault Priority: 5
Fault Frequency: 1
Reset counter: 178
Mileage: 243648 km
Time Indication: 0
Date: 2024.02.03
Time: 12:01:37
Address 08: Auto HVAC Labels: None
Part No SW: 4E0 910 772 A HW: 4E0 820 043 B
Component: Sitzluefter FS H02 010
Revision: 00000024 Serial number: 00000000038963
Shop #: WSC 00000 000 00000
Subsystem 1 - Part No: 4E0 910 772 A
Component: Sitzluefter BFS H02 010
Subsystem 2 - Serial number: 898053000
Subsystem 3 - Serial number: HO18022004065A000000000193ÿ†89
Subsystem 4 - Serial number: 000193ÿ†898053000 000-SHO
Subsystem 5 - Serial number: 000-SHO18022004065A00000000
Subsystem 6 - Serial number: 65A000000000207ÿ
4 Faults Found:
00713 - Centre Left Vent Positioning Motor (V110)
003 - Mechanical Failure
Freeze Frame:
Fault Status: 01100011
Fault Priority: 3
Fault Frequency: 254
Reset counter: 70
Mileage: 243648 km
Time Indication: 0
Date: 2024.02.03
Time: 12:01:41
Freeze Frame:
Voltage: 12.70 V
Temperature: 18.0°C
(no units): 206.0
(no units): 199.0
Temperature: 18.0°C
01087 - Basic Setting Not Performed
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 156
Mileage: 234958 km
Time Indication: 0
Date: 2003.10.18
Time: 15:56:09
00003 - Control Module
003 - Mechanical Failure - Intermittent
Freeze Frame:
Fault Status: 00100011
Fault Priority: 3
Fault Frequency: 5
Reset counter: 88
Mileage: 245339 km
Time Indication: 0
Date: 2024.05.09
Time: 14:51:23
Freeze Frame:
Temperature: 43.0°C
00716 - Air recirculation Flap Positioning Motor (V113)
Freeze Frame:
Fault Priority: 3
Fault Frequency: 2
Reset counter: 109
Mileage: 245751 km
Time Indication: 0
Date: 2024.06.05
Time: 16:35:25
Freeze Frame:
Voltage: 11.10 V
Temperature: 41.0°C
(no units): 173.0
(no units): 199.0
Temperature: 59.0°C
Address 09: Cent. Elect. Labels: 4E0-910-279.clb
Part No SW: 4E0 910 279 G HW: 4E0 907 279 G
Component: ILM Fahrer H12 0170
Coding: 0123113
Subsystem 1 - Part No: 4E1 910 113 B
Component: Wischer WWS D3 H50 0400
Coding: 00000035
Shop #: WSC 02313
Subsystem 2 - Part No: 4E0 910 557 Labels: 8K0-955-559.CLB
Component: REGENLICHTSENSORH10 0030
Coding: 00139548
Shop #: WSC 02313
Address 0E: Media Player 1 Labels: 4E0-910-111.lbl
Part No SW: 4E0 910 111 F HW: 4E0 035 111
Component: CD-Changer H43 0470
Revision: 00000501 Serial number: AUZ5ZBD1035277
VCID: 1C61D9541AAF5AAAABB-8048
Address 13: Auto Dist. Reg
Cannot be reached
Address 15: Airbags Labels: 4E0-910-655-84.lbl
Part No SW: 4E0 910 655 A HW: 4E0 959 655 E
Component: Airbag 8.4E+ H10 0920
Coding: 0530707
1 Fault Found:
01219 - Rear Side Airbag Igniter; Driver Side (N201)
001 - Upper Limit Exceeded - MIL ON
Address 16: Steering wheel Labels: 4E0-910-549.lbl
Part No SW: 4E0 910 549 HW: 4E0 953 549 A
Component: Lenksäulenmodul H13 0040
Coding: 0012241
VCID: 6597BCB069655B62C45-8030
Subsystem 1 - Part No: XXXXXXXXXXX
Component: Lenkradmodul H04 0080
Address 17: Instruments Labels: 4E0-910-xxx-17.lbl
Part No SW: 4E0 910 900 HW: 4E0 920 950 B
Component: KOMBIINSTR. VDO H44 0090
Revision: D15 Serial number: AUDID3D2005413
Coding: 0001600
Shop #: WSC 73814 153 435846
VCID: 5CE199545A2F1AAA6BB-8008
Address 19: CAN Gateway Labels:. 4E0-910-468.clb
Part No SW: 4E0 910 468 A HW: 4E0 907 468 C
Component: Gateway H07 0040
Revision: 07 Serial number: 0500504213165F
Coding: 7EFE77DC3BA705
Shop #: WSC 12345 123 12345
VCID: 2615FBBC54E3907A0DF-8072
7 Faults Found:
00565 - Rear A/C Control Head (Climatronic) (E265)
004 - No Signal/Communication
Freeze Frame:
Fault Status: 01100100
Fault Priority: 2
Reset counter: 70
Mileage: 243971 km
Time Indication: 0
Date: 2024.02.29
Time: 09:34:55
01044 - Control Module Incorrectly Coded
000 - -
Freeze Frame:
Fault Status: 01100000
Fault Priority: 1
Reset counter: 70
Mileage: 243971 km
Time Indication: 0
Date: 2024.02.29
Time: 09:34:55
02077 - Media Player Position 2 (R119)
Freeze Frame:
Fault Priority: 3
Reset counter: 70
Mileage: 243971 km
Time Indication: 0
Date: 2024.02.29
Time: 09:36:22
01304 - Radio
Freeze Frame:
Fault Priority: 3
Reset counter: 70
Mileage: 243971 km
Time Indication: 0
Date: 2024.02.29
Time: 09:36:22
02074 - Rear Left Information Display Control Head Control Module (J648)
Freeze Frame:
Fault Priority: 3
Reset counter: 70
Mileage: 243971 km
Time Indication: 0
Date: 2024.02.29
Time: 09:36:22
02075 - Rear Right Information Display Control Head Control Module (J649)
Freeze Frame:
Fault Priority: 3
Reset counter: 70
Mileage: 243971 km
Time Indication: 0
Date: 2024.02.29
Time: 09:36:22
00467 - TV Tuner (R78)
Freeze Frame:
Fault Priority: 3
Reset counter: 70
Mileage: 243971 km
Time Indication: 0
Date: 2024.02.29
Time: 09:36:22
Address 1E: Media Player 2
Cannot be reached
Address 25: Immobilizer Labels: 4E0-910-131.lbl
Coding: 0263168
Component: ELV 1834
4E0905852D ELV 1834
1 Fault Found:
Freeze Frame:
Fault Priority: 2
Fault Frequency: 7
Reset counter: 88
Mileage: 244272 km
Time Indication: 0
Date: 2024.03.22
Time: 14:38:26
Address 28: HVAC, Rear
Cannot be reached
Address 34: Level Control Labels: 4E0-910-553.clb
Part No SW: 4E0 910 553 E HW: 4E0 907 553 E
Component: LUFTFDR.-CDC H05 4290
Coding: 0015510
VCID: 2517FCB029E59B62045-8070
8 Faults Found:
01772 - Signal from Level Control Pressure Sensor (G291)
009 - Open or Short to Ground
Freeze Frame:
Fault Status: 11101001
Fault Priority: 3
Fault Frequency: 4
Reset counter: 70
Mileage: 0 km
Time Indication: 0
00807 - Suspension Strut Valve; Rear Left (N150)
Freeze Frame:
Fault Priority: 2
Fault Frequency: 4
Reset counter: 70
Mileage: 244548 km
Time Indication: 0
Date: 2024.04.04
Time: 14:49:29
00808 - Suspension Strut Valve; Rear Right (N151)
Freeze Frame:
Fault Priority: 2
Fault Frequency: 4
Reset counter: 70
Mileage: 244548 km
Time Indication: 0
Date: 2024.04.04
Time: 14:49:29
00805 - Suspension Strut Valve; Left Front (N148)
Freeze Frame:
Fault Priority: 2
Fault Frequency: 4
Reset counter: 70
Mileage: 244548 km
Time Indication: 0
Date: 2024.04.04
Time: 14:49:29
00806 - Suspension Strut Valve; Front Right (N149)
Freeze Frame:
Fault Priority: 2
Fault Frequency: 4
Reset counter: 70
Mileage: 244548 km
Time Indication: 0
Date: 2024.04.04
Time: 14:49:30
01397 - Venting Solenoid for Level Control (N111)
Freeze Frame:
Fault Priority: 2
Fault Frequency: 2
Reset counter: 70
Mileage: 244548 km
Time Indication: 0
Date: 2024.04.04
Time: 14:49:30
01316 - ABS Control Module
013 - Check DTC Memory
Freeze Frame:
Fault Status: 11101101
Fault Priority: 3
Fault Frequency: 1
Reset counter: 70
Mileage: 245756 km
Time Indication: 0
Date: 2024.06.05
Time: 17:14:04
00142 - Left Front Dampening Adjustment Valve (N336)
Freeze Frame:
Fault Status: 11101100
Fault Priority: 3
Fault Frequency: 2
Reset counter: 70
Mileage: 245751 km
Time Indication: 0
Date: 2024.06.05
Time: 16:35:06
Address 36: Seat Mem. Drvr Labels: None
Component: Sitzmemory FS H07 0060
Coding: 4071522
Address 37: Navigation Labels: 4E0-910-88x-37.lbl
Part No SW: 4E0 910 887 K HW: 4E0 919 887 C
Component: MNS US H43 0570
Revision: 00000000 Serial number: 355CO047516454
VCID: 35372CF09945EBE2B45-8060
2 Faults Found:
014 - Defective
Freeze Frame:
Fault Priority: 5
Fault Frequency: 1
Reset counter: 0
Mileage: 243648 km
Time Indication: 0
Date: 2024.02.03
Time: 12:05:57
Freeze Frame:
Bin. Bits: 0100
02444 - Disk Drive Load / Eject Malfunction
000 - -
Freeze Frame:
Fault Priority: 5
Fault Frequency: 255
Reset counter: 70
Mileage: 243648 km
Time Indication: 0
Date: 2024.02.03
Time: 11:53:37
Address 38: Roof Electronics Labels: 4E0-910-135.lbl
Part No SW: 4E0 910 135 A HW: 4E0 907 135
Component: Dachknoten D3 H01 0090
Serial number: 00000405400109
Coding: 0003477
VCID: 1D67D45001B553A25C5-8048
2 Faults Found:
02147 - Front Reading Lamp Button (E328); Left
Freeze Frame:
Fault Status: 01101100
Fault Priority: 0
Fault Frequency: 1
Reset counter: 178
Mileage: 243648 km
Time Indication: 0
Date: 2022.02.03
Time: 11:54:00
00410 - Pre-Selection Signal for Opening Sunroof
007 - Short to Ground - Intermittent
Freeze Frame:
Fault Status: 00100111
Fault Priority: 0
Fault Frequency: 15
Reset counter: 108
Mileage: 243760 km
Time Indication: 0
Date: 2022.02.11
Time: 18:04:00
Address 42: Door Elect, Driver Labels: 4E1-910-802-42.lbl
Part No SW: 4E1 910 802 B HW: 4E1 959 801 B
Component: Türsteuer.FS BRM002 0060
Coding: 0028204
VCID: 2019EDA436C77E4A773-8074
Address 46: Central Conv. Labels:. 4E0-910-289.lbl
Part No SW: 4E0 910 289 A HW: 4E0 907 289
Component: Komfortgeraet H04 0040
Revision: 00400004 Serial number: W040402230111
Coding: 0065086
VCID: 270BF6B853E98972369-8072
Subsystem 1 - Part No: 4E0 910 853
Component: Heckdeckel H06 0060
Subsystem 2 - Part No: 4E0 907 719
Component: Neigungssensor H03 0020
1 Fault Found:
01134 - Alarm Horn (H12)
Freeze Frame:
Fault Priority: 3
Reset counter: 148
Mileage: 180748 km
Time Indication: 0
Date: 2003.10.08
Time: 02:43:50
Address 47: Sound System Labels: None
Part No SW: 4E0 910 224 C HW: 4E0 035 223 B
Component: DSP-High D3/AUX H13 0470
Revision: Dev_D01 Serial number: 00000000000173
Coding: 0000008
Shop #: WSC 12345 111 45799
VCID: 1E65D35C0CB348BA45F-804A
2 Faults Found:
000 - -
Freeze Frame:
Fault Priority: 7
Reset counter: 70
Mileage: 227538 km
Time Indication: 0
Date: 2004.03.17
Time: 15:27:04
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 61
Mileage: 205298 km
Time Indication: 0
Date: 2018.12.20
Time: 17:26:42
Address 4E: Ctrl Head RR
Cannot be reached
Address 4F: Centr. Electr. II Labels: None
Part No SW: 4E0 910 280 A HW: 4E0 907 280 A
Component: ILM Beifahrer H09 0040
Revision: Serial number: 00000000035530
Coding: 0010111
Shop #: WSC 11111 111 45799
5 Faults Found:
02268 - Switch to Deploy Display Unit
Freeze Frame:
Fault Status: 01100111
Fault Priority: 4
Reset counter: 70
Mileage: 243648 km
Time Indication: 0
Date: 2001.08.30
Time: 11:54:00
Freeze Frame:
Fault Status: 01101101
Fault Priority: 3
Fault Frequency: 6
Reset counter: 70
Mileage: 245724 km
Time Indication: 0
Date: 2001.12.25
Time: 16:28:00
02269 - No Acknowledgment from Limit-Shut Off at Display Unit Retraction
Freeze Frame:
Fault Priority: 4
Reset counter: 70
Mileage: 243648 km
Time Indication: 0
Date: 2001.08.30
Time: 12:33:00
02270 - No Acknowledgment from Limit-Shut Off at Display Unit Deployment
Freeze Frame:
Fault Status: 01110100
Fault Priority: 4
Reset counter: 70
Mileage: 243648 km
Time Indication: 0
Date: 2001.08.30
Time: 12:04:00
02258 - Door Opener Transmitter
Freeze Frame:
Fault Priority: 3
Reset counter: 70
Mileage: 243648 km
Time Indication: 0
Date: 2001.08.30
Time: 11:53:00
Address 52: Door Elect, Pass. Labels: 4E1-910-802-52.lbl
Part No SW: 4E1 910 802 HW: 4E1 959 802
Component: Türsteuer.BF BRM007 0110
Coding: 0028196
VCID: 5EE5935C4C3308BA05F-800A
1 Fault Found:
01482 - Motors for Central Locking
006 - Short to Plus - Intermittent
Freeze Frame:
Fault Status: 00100110
Fault Priority: 2
Fault Frequency: 14
Reset counter: 110
Mileage: 245744 km
Time Indication: 0
Date: 2024.06.05
Time: 16:47:54
Address 53: Parking Brake Labels: 4E0-910-801.clb
Part No SW: 4E0 910 801 A HW: 4E0 907 801
Component: EPB AV1C1010 H01 1010
Revision: AV1C1010
Coding: 0000532
2 Faults Found:
013 - Check DTC Memory - Intermittent
Freeze Frame:
Fault Status: 00101101
Fault Priority: 3
Fault Frequency: 23
Reset counter: 110
Mileage: 245720 km
Time Indication: 0
Date: 2024.05.30
Time: 16:28:45
Freeze Frame:
Voltage: 11.18 V
Count: 236
02596 - Rear Brake Pads Worn
008 - Implausible Signal
Freeze Frame:
Fault Status: 01111000
Fault Priority: 6
Fault Frequency: 1
Reset counter: 196
Mileage: 230664 km
Time Indication: 0
Date: 2003.10.08
Time: 00:02:14
Freeze Frame:
Voltage: 11.18 V
Count: 61
Address 55: Headlight Range Labels: 4E0-910-357.lbl
Part No SW: 4E0 910 357 HW: 4E0 907 357
Component: Pre-AFS H01 0040
Coding: 0000001
VCID: 629DA7AC784B2C5A217-8036
Address 56: Radio
Cannot be reached
Address 57: TV Tuner
Cannot be reached
Address 5E: Ctrl Head LR
Cannot be reached
Address 61: Battery Regul. Labels: 4E0-910-181.lbl
Part No SW: 4E0 910 181 B HW: 4E0 915 181
Component: ENERGIEMANAGER H02 0240
Revision: 00000000 Serial number: 00000001376276
Subsystem 1 - Part No: 000 915 105 AK
Component: von VA0 2512192105
Coding: 303030393135313035414B56413032353132313932313035
Shop #: WSC 22308 444 00872
1 Fault Found:
00992 - Consumption Cut-Off Active
000 - - - Intermittent
Freeze Frame:
Fault Status: 00100000
Fault Priority: 7
Fault Frequency: 1
Reset counter: 255
Mileage: 245389 km
Time Indication: 0
Date: 2024.05.15
Time: 13:38:07
Address 62: Door, Rear Left Labels: 4E0-910-802.lbl
Part No SW: 4E0 910 802 HW: 4E0 959 801 A
Component: Türsteuer.HL BRM007 0110
Coding: 0028196
VCID: 5DE79450413513A21C5-8008
Address 72: Door, Rear Right Labels: 4E0-910-802.lbl
Part No SW: 4E0 910 802 HW: 4E0 959 802 A
Component: Türsteuer.HR BRM007 0110
Coding: 0028196
1 Fault Found:
02115 - Locking Unit for Central Locking
Freeze Frame:
Fault Status: 01101000
Fault Priority: 2
Fault Frequency: 1
Reset counter: 64
Mileage: 245680 km
Time Indication: 0
Date: 2024.05.26
Time: 11:01:06
Address 75: Telematics Labels: None
Part No SW: 4E0 910 616 HW: 4E0 035 616 A
Component: Telematik USA1 0070
Revision: 00000004 Serial number: 0000ATD3008587
Coding: 0000005
VCID: 6099ADA476573E4A373-5160
1 Fault Found:
01531 - Emergency Battery
002 - Lower Limit Exceeded - MIL ON
Address 76: Park Assist Labels: 4E0-910-283.lbl
Part No SW: 4E0 910 283 A HW: 4E0 919 283 B
Component: Parkhilfe 8-Kan H12 0020
Revision: --.--.-- Serial number: 08730405500663
Coding: 0001208
VCID: 211FE8A03DCD774278D-8074
3 Faults Found:
01626 - Sensor for Parking-Aid; Front Right (G252)
Freeze Frame:
Fault Status: 01101001
Fault Priority: 3
Fault Frequency: 1
Reset counter: 178
Mileage: 243648 km
Time Indication: 0
Date: 2024.02.05
Time: 08:20:39
01627 - Sensor for Parking-Aid; Front Mid-Right (G253)
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 178
Mileage: 243648 km
Time Indication: 0
Date: 2024.02.05
Time: 08:20:39
01629 - Sensor for Parking-Aid; Front Left (G255)
Freeze Frame:
Fault Priority: 3
Fault Frequency: 5
Reset counter: 69
Mileage: 243648 km
Time Indication: 0
Date: 2024.02.05
Time: 08:20:38
End----(Elapsed Time: 02:29, VBatt start/end: 11.8V/11.9V. VIgn 11.9V)-----
6/23 -- Sunday,23,June,2024,17:09:19:18900
www.Ross-Tech.com
VIN: WAUML44E14N022231 Mileage: 245840km-152757miles
0E-Media Player 1 -- Status: Malfunction 0010
55-Headlight Range -- Status: Malfunction 0010
Coding: 0007773
3 Faults Found:
17755 - Camshaft Position Sensor 2 (G163) / Engine Speed Sensor (G28)
P1347 - 002 - Incor. Correl. - MIL ON
Readiness: 0010 1001
Coding: 0000002
Coding: 0007597
4 Faults Found:
014 - Defective
00290 - ABS Wheel Speed Sensor; Rear Left (G46)
012 - Electrical Fault in Circuit - Intermittent
00778 - Steering Angle Sensor (G85)
008 - Implausible Signal - Intermittent
Coding: 0263168
Component: ELV XXXX
1 Fault Found:
Freeze Frame:
Fault Priority: 2
Fault Frequency: 5
Reset counter: 120
Mileage: 245808 km
Time Indication: 0
Date: 2003.10.11
Time: 20:41:50
Coding: 3940448
Coding: 0000003
4 Faults Found:
Freeze Frame:
Fault Priority: 5
Fault Frequency: 1
Reset counter: 159
Mileage: 178306 km
Time Indication: 0
Date: 2003.10.08
Time: 00:00:10
014 - Defective
Freeze Frame:
Fault Priority: 5
Fault Frequency: 1
Reset counter: 74
Mileage: 245801 km
Time Indication: 0
Date: 2003.10.10
Time: 14:46:26
00384 - Optical Databus
011 - Open Circuit - Intermittent
Freeze Frame:
Fault Status: 00101011
Fault Priority: 5
Fault Frequency: 13
Reset counter: 120
Mileage: 245845 km
Time Indication: 0
Date: 2003.10.18
Time: 19:57:22
02260 - Display Unit; Temperature Error
001 - Upper Limit Exceeded - Intermittent
Freeze Frame:
Fault Status: 00100001
Fault Priority: 5
Fault Frequency: 1
Reset counter: 115
Mileage: 245816 km
Time Indication: 0
Date: 2003.10.11
Time: 13:06:19
Freeze Frame:
Temperature: 91.0°C
Part No SW: 4E0 910 043 A HW: 4E0 820 043 B
Component: KLIMAAUTOMAT 016 0300
Coding: 1085761
VCID: 1B63DA481FA15D92A21-804E
Subsystem 2 - Part No: 4E0 910 772 A
Subsystem 3 - Serial number: 898053000
Subsystem 4 - Serial number: HO18022004065A000000000193ÿ†89
Subsystem 5 - Serial number: 000193ÿ†898053000 000-SHO
Subsystem 6 - Serial number: 000-SHO18022004065A00000000
Subsystem 7 - Serial number: 65A000000000207ÿ
3 Faults Found:
Freeze Frame:
Fault Priority: 3
Fault Frequency: 21
Reset counter: 80
Mileage: 245801 km
Time Indication: 0
Date: 2003.10.10
Time: 14:46:29
Freeze Frame:
Voltage: 11.80 V
Temperature: 30.0°C
(no units): 206.0
(no units): 199.0
Temperature: 57.0°C
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 156
Mileage: 234958 km
Time Indication: 0
Date: 2003.10.18
Time: 15:56:09
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 116
Mileage: 245832 km
Time Indication: 0
Date: 2003.10.12
Time: 18:39:46
Freeze Frame:
Voltage: 11.00 V
Temperature: 41.0°C
(no units): 173.0
(no units): 199.0
Temperature: 56.0°C
Coding: 0123113
Coding: 00000035
Shop #: WSC 02313
Coding: 00139548
Shop #: WSC 02313
1 Fault Found:
02446 - Disk Drive Mechanical Malfunction
014 - Defective
Freeze Frame:
Fault Priority: 7
Fault Frequency: 20
Reset counter: 0
Time Indication: 0
Cannot be reached
Coding: 0530707
1 Fault Found:
Coding: 0012241
Coding: 0001600
8 Faults Found:
Freeze Frame:
Fault Priority: 2
Fault Frequency: 43
Reset counter: 80
Mileage: 245801 km
Time Indication: 0
Date: 2003.10.10
Time: 14:43:10
000 - -
Freeze Frame:
Fault Priority: 1
Fault Frequency: 21
Reset counter: 80
Mileage: 245801 km
Time Indication: 0
Date: 2003.10.10
Time: 14:43:10
Freeze Frame:
Fault Priority: 3
Fault Frequency: 19
Reset counter: 80
Mileage: 245801 km
Time Indication: 0
Date: 2003.10.10
Time: 14:44:37
01304 - Radio
Freeze Frame:
Fault Priority: 3
Fault Frequency: 19
Reset counter: 80
Mileage: 245801 km
Time Indication: 0
Date: 2003.10.10
Time: 14:44:37
Freeze Frame:
Fault Priority: 3
Fault Frequency: 19
Reset counter: 80
Mileage: 245801 km
Time Indication: 0
Date: 2003.10.10
Time: 14:44:37
Freeze Frame:
Fault Priority: 3
Fault Frequency: 19
Reset counter: 80
Mileage: 245801 km
Time Indication: 0
Date: 2003.10.10
Time: 14:44:37
Freeze Frame:
Fault Priority: 3
Fault Frequency: 19
Reset counter: 80
Mileage: 245801 km
Time Indication: 0
Date: 2003.10.10
Time: 14:44:37
Freeze Frame:
Fault Priority: 5
Fault Frequency: 8
Reset counter: 120
Mileage: 245845 km
Time Indication: 0
Date: 2003.10.18
Time: 19:57:53
Cannot be reached
Coding: 0263168
Component: ELV XXXX
XXXXXXXXXXX ELV XXXX
1 Fault Found:
Freeze Frame:
Fault Priority: 2
Fault Frequency: 5
Reset counter: 120
Mileage: 245808 km
Time Indication: 0
Date: 2003.10.11
Time: 20:41:50
Cannot be reached
Coding: 0015510
8 Faults Found:
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 80
Mileage: 245845 km
Time Indication: 0
Date: 2003.10.20
Time: 17:03:17
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 80
Mileage: 245845 km
Time Indication: 0
Date: 2003.10.20
Time: 17:03:17
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 80
Mileage: 245845 km
Time Indication: 0
Date: 2003.10.20
Time: 17:03:17
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 80
Mileage: 245845 km
Time Indication: 0
Date: 2003.10.20
Time: 17:03:18
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 80
Mileage: 245845 km
Time Indication: 0
Date: 2003.10.19
Time: 18:14:34
00144 - Rear Left Dampening Adjustment Valve (N338)
Freeze Frame:
Fault Status: 00101100
Fault Priority: 3
Fault Frequency: 1
Reset counter: 120
Mileage: 245845 km
Time Indication: 0
Date: 2003.10.19
Time: 18:17:56
00143 - Front Right Dampening Adjustment Valve (N337)
Freeze Frame:
Fault Priority: 3
Fault Frequency: 3
Reset counter: 120
Mileage: 245841 km
Time Indication: 0
Date: 2003.10.16
Time: 07:42:36
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 80
Mileage: 245845 km
Time Indication: 0
Date: 2003.10.20
Time: 17:03:18
Coding: 4071522
2 Faults Found:
014 - Defective
Freeze Frame:
Fault Priority: 5
Fault Frequency: 1
Reset counter: 0
Mileage: 245801 km
Time Indication: 0
Date: 2003.10.10
Time: 15:10:12
Freeze Frame:
Bin. Bits: 0100
000 - -
Freeze Frame:
Fault Priority: 5
Fault Frequency: 55
Reset counter: 80
Mileage: 245801 km
Time Indication: 0
Date: 2003.10.10
Time: 14:44:33
Coding: 0003477
2 Faults Found:
Freeze Frame:
Fault Priority: 0
Fault Frequency: 1
Reset counter: 74
Mileage: 245800 km
Time Indication: 0
Date: 2003.10.10
Time: 14:43:00
Freeze Frame:
Fault Priority: 0
Fault Frequency: 15
Reset counter: 120
Mileage: 245808 km
Time Indication: 0
Date: 2003.10.11
Time: 10:25:00
Coding: 0028204
Coding: 0065086
1 Fault Found:
Freeze Frame:
Fault Priority: 3
Reset counter: 148
Mileage: 180748 km
Time Indication: 0
Date: 2003.10.08
Time: 02:43:50
Coding: 0000008
2 Faults Found:
000 - -
Freeze Frame:
Fault Priority: 7
Reset counter: 80
Mileage: 227538 km
Time Indication: 0
Date: 2004.03.17
Time: 15:27:04
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 61
Mileage: 205298 km
Time Indication: 0
Date: 2018.12.20
Time: 17:26:42
Cannot be reached
Coding: 0010111
5 Faults Found:
Freeze Frame:
Fault Priority: 4
Fault Frequency: 40
Reset counter: 80
Mileage: 245800 km
Time Indication: 0
Date: 2003.10.10
Time: 14:43:00
Freeze Frame:
Fault Priority: 3
Fault Frequency: 25
Reset counter: 118
Mileage: 245800 km
Time Indication: 0
Date: 2003.10.10
Time: 14:43:00
Freeze Frame:
Fault Priority: 4
Fault Frequency: 42
Reset counter: 80
Mileage: 245800 km
Time Indication: 0
Date: 2003.10.10
Time: 15:10:00
Freeze Frame:
Fault Priority: 4
Fault Frequency: 36
Reset counter: 80
Mileage: 245800 km
Time Indication: 0
Date: 2003.10.10
Time: 14:48:00
Freeze Frame:
Fault Priority: 3
Fault Frequency: 23
Reset counter: 80
Mileage: 245800 km
Time Indication: 0
Date: 2003.10.10
Time: 14:43:00
Coding: 0028196
1 Fault Found:
Freeze Frame:
Fault Priority: 2
Fault Frequency: 14
Reset counter: 120
Mileage: 245840 km
Time Indication: 0
Date: 2003.10.19
Time: 11:41:00
Revision: AV1C1010
Coding: 0000532
1 Fault Found:
008 - Implausible Signal - MIL ON
Freeze Frame:
Fault Status: 11101000
Fault Priority: 3
Fault Frequency: 69
Reset counter: 80
Mileage: 245768 km
Time Indication: 0
Date: 2003.10.08
Time: 00:01:46
Freeze Frame:
Voltage: 9.63 V
Count: 231
Coding: 0000001
1 Fault Found:
013 - Check DTC Memory - MIL ON
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 80
Mileage: 245800 km
Time Indication: 0
Date: 2003.10.10
Time: 14:46:50
Address 56: Radio
Cannot be reached
Cannot be reached
Cannot be reached
5 Faults Found:
02273 - Quiescent Current Stage 2
Freeze Frame:
Fault Priority: 7
Fault Frequency: 18
Reset counter: 255
Mileage: 245816 km
Time Indication: 0
Date: 2003.10.11
Time: 12:39:47
02276 - Quiescent Current Stage 5
Freeze Frame:
Fault Priority: 7
Fault Frequency: 18
Reset counter: 255
Mileage: 245816 km
Time Indication: 0
Date: 2003.10.11
Time: 15:30:05
02274 - Quiescent Current Stage 3
Freeze Frame:
Fault Priority: 7
Fault Frequency: 18
Reset counter: 255
Mileage: 245816 km
Time Indication: 0
Date: 2003.10.11
Time: 16:25:35
02277 - Quiescent Current Stage 6
Freeze Frame:
Fault Priority: 7
Fault Frequency: 18
Reset counter: 255
Mileage: 245816 km
Time Indication: 0
Date: 2003.10.11
Time: 16:26:17
02256 - Quiescent Current
Freeze Frame:
Fault Priority: 7
Fault Frequency: 2
Reset counter: 120
Mileage: 245845 km
Time Indication: 0
Date: 2003.10.20
Time: 00:46:06
Coding: 0028196
Coding: 0028196
1 Fault Found:
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 74
Mileage: 245792 km
Time Indication: 0
Date: 2003.10.10
Time: 14:43:10
Coding: 0000005
VCID: 6099ADA476573E4A373-513C
1 Fault Found:
Coding: 0001208
3 Faults Found:
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 74
Mileage: 245803 km
Time Indication: 0
Date: 2003.10.10
Time: 15:25:10
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 74
Mileage: 245803 km
Time Indication: 0
Date: 2003.10.10
Time: 15:25:10
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 74
Mileage: 245803 km
Time Indication: 0
Date: 2003.10.10
Time: 15:25:09
End----(Elapsed Time: 02:28, VBatt start/end: 11.7V/11.8V. VIgn 11.8V)-----
Thank you..
www.Ross-Tech.com
Coding: 0007773
5 Faults Found:
Coding: 0000002
1 Fault Found:
18265 - Load Signal
Freeze Frame:
RPM: 1728 /min
RPM: 1312 /min
RPM: 1504 /min
(no units): 5.0
(no units): 59.0
Temperature: 91.0°C
T.B. Angle: 19.2°
Voltage: 11.20 V
Coding: 0007597
2 Faults Found:
18265 - Load Signal
Coding: 0263168
Component: ELV 1834
1 Fault Found:
Freeze Frame:
Fault Priority: 2
Fault Frequency: 7
Reset counter: 88
Mileage: 244272 km
Time Indication: 0
Date: 2024.03.22
Time: 14:38:26
Coding: 3940448
Coding: 0000003
2 Faults Found:
Freeze Frame:
Fault Priority: 5
Fault Frequency: 1
Reset counter: 159
Mileage: 178306 km
Time Indication: 0
Date: 2003.10.08
Time: 00:00:10
014 - Defective
Freeze Frame:
Fault Priority: 5
Fault Frequency: 1
Reset counter: 178
Mileage: 243648 km
Time Indication: 0
Date: 2024.02.03
Time: 12:01:37
4 Faults Found:
Freeze Frame:
Fault Priority: 3
Reset counter: 70
Mileage: 243648 km
Time Indication: 0
Date: 2024.02.03
Time: 12:01:41
Freeze Frame:
Voltage: 12.70 V
Temperature: 18.0°C
(no units): 206.0
(no units): 199.0
Temperature: 18.0°C
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 156
Mileage: 234958 km
Time Indication: 0
Date: 2003.10.18
Time: 15:56:09
Freeze Frame:
Fault Priority: 3
Fault Frequency: 5
Reset counter: 88
Mileage: 245339 km
Time Indication: 0
Date: 2024.05.09
Time: 14:51:23
Freeze Frame:
Temperature: 43.0°C
Freeze Frame:
Fault Priority: 3
Fault Frequency: 2
Reset counter: 109
Mileage: 245751 km
Time Indication: 0
Date: 2024.06.05
Time: 16:35:25
Freeze Frame:
Voltage: 11.10 V
Temperature: 41.0°C
(no units): 173.0
(no units): 199.0
Temperature: 59.0°C
Coding: 0123113
Coding: 00000035
Shop #: WSC 02313
Coding: 00139548
Shop #: WSC 02313
Cannot be reached
Coding: 0530707
1 Fault Found:
Coding: 0012241
Coding: 0001600
7 Faults Found:
Freeze Frame:
Fault Priority: 2
Reset counter: 70
Mileage: 243971 km
Time Indication: 0
Date: 2024.02.29
Time: 09:34:55
000 - -
Freeze Frame:
Fault Priority: 1
Reset counter: 70
Mileage: 243971 km
Time Indication: 0
Date: 2024.02.29
Time: 09:34:55
Freeze Frame:
Fault Priority: 3
Reset counter: 70
Mileage: 243971 km
Time Indication: 0
Date: 2024.02.29
Time: 09:36:22
01304 - Radio
Freeze Frame:
Fault Priority: 3
Reset counter: 70
Mileage: 243971 km
Time Indication: 0
Date: 2024.02.29
Time: 09:36:22
Freeze Frame:
Fault Priority: 3
Reset counter: 70
Mileage: 243971 km
Time Indication: 0
Date: 2024.02.29
Time: 09:36:22
Freeze Frame:
Fault Priority: 3
Reset counter: 70
Mileage: 243971 km
Time Indication: 0
Date: 2024.02.29
Time: 09:36:22
Freeze Frame:
Fault Priority: 3
Reset counter: 70
Mileage: 243971 km
Time Indication: 0
Date: 2024.02.29
Time: 09:36:22
Cannot be reached
Coding: 0263168
Component: ELV 1834
4E0905852D ELV 1834
1 Fault Found:
Freeze Frame:
Fault Priority: 2
Fault Frequency: 7
Reset counter: 88
Mileage: 244272 km
Time Indication: 0
Date: 2024.03.22
Time: 14:38:26
Cannot be reached
Coding: 0015510
8 Faults Found:
Freeze Frame:
Fault Priority: 3
Fault Frequency: 4
Reset counter: 70
Mileage: 0 km
Time Indication: 0
Freeze Frame:
Fault Priority: 2
Fault Frequency: 4
Reset counter: 70
Mileage: 244548 km
Time Indication: 0
Date: 2024.04.04
Time: 14:49:29
Freeze Frame:
Fault Priority: 2
Fault Frequency: 4
Reset counter: 70
Mileage: 244548 km
Time Indication: 0
Date: 2024.04.04
Time: 14:49:29
Freeze Frame:
Fault Priority: 2
Fault Frequency: 4
Reset counter: 70
Mileage: 244548 km
Time Indication: 0
Date: 2024.04.04
Time: 14:49:29
Freeze Frame:
Fault Priority: 2
Fault Frequency: 4
Reset counter: 70
Mileage: 244548 km
Time Indication: 0
Date: 2024.04.04
Time: 14:49:30
Freeze Frame:
Fault Priority: 2
Fault Frequency: 2
Reset counter: 70
Mileage: 244548 km
Time Indication: 0
Date: 2024.04.04
Time: 14:49:30
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 70
Mileage: 245756 km
Time Indication: 0
Date: 2024.06.05
Time: 17:14:04
Freeze Frame:
Fault Priority: 3
Fault Frequency: 2
Reset counter: 70
Mileage: 245751 km
Time Indication: 0
Date: 2024.06.05
Time: 16:35:06
Coding: 4071522
2 Faults Found:
014 - Defective
Freeze Frame:
Fault Priority: 5
Fault Frequency: 1
Reset counter: 0
Mileage: 243648 km
Time Indication: 0
Date: 2024.02.03
Time: 12:05:57
Freeze Frame:
Bin. Bits: 0100
000 - -
Freeze Frame:
Fault Priority: 5
Reset counter: 70
Mileage: 243648 km
Time Indication: 0
Date: 2024.02.03
Time: 11:53:37
Coding: 0003477
2 Faults Found:
Freeze Frame:
Fault Priority: 0
Fault Frequency: 1
Reset counter: 178
Mileage: 243648 km
Time Indication: 0
Date: 2022.02.03
Time: 11:54:00
Freeze Frame:
Fault Priority: 0
Fault Frequency: 15
Reset counter: 108
Mileage: 243760 km
Time Indication: 0
Date: 2022.02.11
Time: 18:04:00
Coding: 0028204
Coding: 0065086
1 Fault Found:
Freeze Frame:
Fault Priority: 3
Reset counter: 148
Mileage: 180748 km
Time Indication: 0
Date: 2003.10.08
Time: 02:43:50
Coding: 0000008
2 Faults Found:
000 - -
Freeze Frame:
Fault Priority: 7
Reset counter: 70
Mileage: 227538 km
Time Indication: 0
Date: 2004.03.17
Time: 15:27:04
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 61
Mileage: 205298 km
Time Indication: 0
Date: 2018.12.20
Time: 17:26:42
Cannot be reached
Coding: 0010111
5 Faults Found:
Freeze Frame:
Fault Priority: 4
Reset counter: 70
Mileage: 243648 km
Time Indication: 0
Date: 2001.08.30
Time: 11:54:00
Freeze Frame:
Fault Priority: 3
Fault Frequency: 6
Reset counter: 70
Mileage: 245724 km
Time Indication: 0
Date: 2001.12.25
Time: 16:28:00
Freeze Frame:
Fault Priority: 4
Reset counter: 70
Mileage: 243648 km
Time Indication: 0
Date: 2001.08.30
Time: 12:33:00
Freeze Frame:
Fault Priority: 4
Reset counter: 70
Mileage: 243648 km
Time Indication: 0
Date: 2001.08.30
Time: 12:04:00
Freeze Frame:
Fault Priority: 3
Reset counter: 70
Mileage: 243648 km
Time Indication: 0
Date: 2001.08.30
Time: 11:53:00
Coding: 0028196
1 Fault Found:
Freeze Frame:
Fault Priority: 2
Fault Frequency: 14
Reset counter: 110
Mileage: 245744 km
Time Indication: 0
Date: 2024.06.05
Time: 16:47:54
Revision: AV1C1010
Coding: 0000532
2 Faults Found:
Freeze Frame:
Fault Priority: 3
Fault Frequency: 23
Reset counter: 110
Mileage: 245720 km
Time Indication: 0
Date: 2024.05.30
Time: 16:28:45
Freeze Frame:
Voltage: 11.18 V
Count: 236
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 196
Mileage: 230664 km
Time Indication: 0
Date: 2003.10.08
Time: 00:02:14
Freeze Frame:
Voltage: 11.18 V
Count: 61
Coding: 0000001
Address 56: Radio
Cannot be reached
Cannot be reached
Cannot be reached
1 Fault Found:
Freeze Frame:
Fault Priority: 7
Fault Frequency: 1
Reset counter: 255
Mileage: 245389 km
Time Indication: 0
Date: 2024.05.15
Time: 13:38:07
Coding: 0028196
Coding: 0028196
1 Fault Found:
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 64
Mileage: 245680 km
Time Indication: 0
Date: 2024.05.26
Time: 11:01:06
Coding: 0000005
1 Fault Found:
Coding: 0001208
3 Faults Found:
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 178
Mileage: 243648 km
Time Indication: 0
Date: 2024.02.05
Time: 08:20:39
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 178
Mileage: 243648 km
Time Indication: 0
Date: 2024.02.05
Time: 08:20:39
Freeze Frame:
Fault Priority: 3
Fault Frequency: 5
Reset counter: 69
Mileage: 243648 km
Time Indication: 0
Date: 2024.02.05
Time: 08:20:38
www.Ross-Tech.com
Coding: 0007773
3 Faults Found:
Coding: 0000002
Coding: 0007597
4 Faults Found:
014 - Defective
Coding: 0263168
Component: ELV XXXX
1 Fault Found:
Freeze Frame:
Fault Priority: 2
Fault Frequency: 5
Reset counter: 120
Mileage: 245808 km
Time Indication: 0
Date: 2003.10.11
Time: 20:41:50
Coding: 3940448
Coding: 0000003
4 Faults Found:
Freeze Frame:
Fault Priority: 5
Fault Frequency: 1
Reset counter: 159
Mileage: 178306 km
Time Indication: 0
Date: 2003.10.08
Time: 00:00:10
014 - Defective
Freeze Frame:
Fault Priority: 5
Fault Frequency: 1
Reset counter: 74
Mileage: 245801 km
Time Indication: 0
Date: 2003.10.10
Time: 14:46:26
Freeze Frame:
Fault Priority: 5
Fault Frequency: 13
Reset counter: 120
Mileage: 245845 km
Time Indication: 0
Date: 2003.10.18
Time: 19:57:22
Freeze Frame:
Fault Priority: 5
Fault Frequency: 1
Reset counter: 115
Mileage: 245816 km
Time Indication: 0
Date: 2003.10.11
Time: 13:06:19
Freeze Frame:
Temperature: 91.0°C
Coding: 1085761
3 Faults Found:
Freeze Frame:
Fault Priority: 3
Fault Frequency: 21
Reset counter: 80
Mileage: 245801 km
Time Indication: 0
Date: 2003.10.10
Time: 14:46:29
Freeze Frame:
Voltage: 11.80 V
Temperature: 30.0°C
(no units): 206.0
(no units): 199.0
Temperature: 57.0°C
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 156
Mileage: 234958 km
Time Indication: 0
Date: 2003.10.18
Time: 15:56:09
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 116
Mileage: 245832 km
Time Indication: 0
Date: 2003.10.12
Time: 18:39:46
Freeze Frame:
Voltage: 11.00 V
Temperature: 41.0°C
(no units): 173.0
(no units): 199.0
Temperature: 56.0°C
Coding: 0123113
Coding: 00000035
Shop #: WSC 02313
Coding: 00139548
Shop #: WSC 02313
1 Fault Found:
014 - Defective
Freeze Frame:
Fault Priority: 7
Fault Frequency: 20
Reset counter: 0
Time Indication: 0
Cannot be reached
Coding: 0530707
1 Fault Found:
Coding: 0012241
Coding: 0001600
8 Faults Found:
Freeze Frame:
Fault Priority: 2
Fault Frequency: 43
Reset counter: 80
Mileage: 245801 km
Time Indication: 0
Date: 2003.10.10
Time: 14:43:10
000 - -
Freeze Frame:
Fault Priority: 1
Fault Frequency: 21
Reset counter: 80
Mileage: 245801 km
Time Indication: 0
Date: 2003.10.10
Time: 14:43:10
Freeze Frame:
Fault Priority: 3
Fault Frequency: 19
Reset counter: 80
Mileage: 245801 km
Time Indication: 0
Date: 2003.10.10
Time: 14:44:37
01304 - Radio
Freeze Frame:
Fault Priority: 3
Fault Frequency: 19
Reset counter: 80
Mileage: 245801 km
Time Indication: 0
Date: 2003.10.10
Time: 14:44:37
Freeze Frame:
Fault Priority: 3
Fault Frequency: 19
Reset counter: 80
Mileage: 245801 km
Time Indication: 0
Date: 2003.10.10
Time: 14:44:37
Freeze Frame:
Fault Priority: 3
Fault Frequency: 19
Reset counter: 80
Mileage: 245801 km
Time Indication: 0
Date: 2003.10.10
Time: 14:44:37
Freeze Frame:
Fault Priority: 3
Fault Frequency: 19
Reset counter: 80
Mileage: 245801 km
Time Indication: 0
Date: 2003.10.10
Time: 14:44:37
Freeze Frame:
Fault Priority: 5
Fault Frequency: 8
Reset counter: 120
Mileage: 245845 km
Time Indication: 0
Date: 2003.10.18
Time: 19:57:53
Cannot be reached
Coding: 0263168
Component: ELV XXXX
1 Fault Found:
Freeze Frame:
Fault Priority: 2
Fault Frequency: 5
Reset counter: 120
Mileage: 245808 km
Time Indication: 0
Date: 2003.10.11
Time: 20:41:50
Cannot be reached
Coding: 0015510
8 Faults Found:
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 80
Mileage: 245845 km
Time Indication: 0
Date: 2003.10.20
Time: 17:03:17
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 80
Mileage: 245845 km
Time Indication: 0
Date: 2003.10.20
Time: 17:03:17
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 80
Mileage: 245845 km
Time Indication: 0
Date: 2003.10.20
Time: 17:03:17
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 80
Mileage: 245845 km
Time Indication: 0
Date: 2003.10.20
Time: 17:03:18
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 80
Mileage: 245845 km
Time Indication: 0
Date: 2003.10.19
Time: 18:14:34
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 120
Mileage: 245845 km
Time Indication: 0
Date: 2003.10.19
Time: 18:17:56
Freeze Frame:
Fault Priority: 3
Fault Frequency: 3
Reset counter: 120
Mileage: 245841 km
Time Indication: 0
Date: 2003.10.16
Time: 07:42:36
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 80
Mileage: 245845 km
Time Indication: 0
Date: 2003.10.20
Time: 17:03:18
Coding: 4071522
2 Faults Found:
014 - Defective
Freeze Frame:
Fault Priority: 5
Fault Frequency: 1
Reset counter: 0
Mileage: 245801 km
Time Indication: 0
Date: 2003.10.10
Time: 15:10:12
Freeze Frame:
Bin. Bits: 0100
000 - -
Freeze Frame:
Fault Priority: 5
Fault Frequency: 55
Reset counter: 80
Mileage: 245801 km
Time Indication: 0
Date: 2003.10.10
Time: 14:44:33
Coding: 0003477
2 Faults Found:
Freeze Frame:
Fault Priority: 0
Fault Frequency: 1
Reset counter: 74
Mileage: 245800 km
Time Indication: 0
Date: 2003.10.10
Time: 14:43:00
Freeze Frame:
Fault Priority: 0
Fault Frequency: 15
Reset counter: 120
Mileage: 245808 km
Time Indication: 0
Date: 2003.10.11
Time: 10:25:00
Coding: 0028204
Coding: 0065086
1 Fault Found:
Freeze Frame:
Fault Priority: 3
Reset counter: 148
Mileage: 180748 km
Time Indication: 0
Date: 2003.10.08
Time: 02:43:50
Coding: 0000008
2 Faults Found:
000 - -
Freeze Frame:
Fault Priority: 7
Reset counter: 80
Mileage: 227538 km
Time Indication: 0
Date: 2004.03.17
Time: 15:27:04
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 61
Mileage: 205298 km
Time Indication: 0
Date: 2018.12.20
Time: 17:26:42
Cannot be reached
Coding: 0010111
5 Faults Found:
Freeze Frame:
Fault Priority: 4
Fault Frequency: 40
Reset counter: 80
Mileage: 245800 km
Time Indication: 0
Date: 2003.10.10
Time: 14:43:00
Freeze Frame:
Fault Priority: 3
Fault Frequency: 25
Reset counter: 118
Mileage: 245800 km
Time Indication: 0
Date: 2003.10.10
Time: 14:43:00
Freeze Frame:
Fault Priority: 4
Fault Frequency: 42
Reset counter: 80
Mileage: 245800 km
Time Indication: 0
Date: 2003.10.10
Time: 15:10:00
Freeze Frame:
Fault Priority: 4
Fault Frequency: 36
Reset counter: 80
Mileage: 245800 km
Time Indication: 0
Date: 2003.10.10
Time: 14:48:00
Freeze Frame:
Fault Priority: 3
Fault Frequency: 23
Reset counter: 80
Mileage: 245800 km
Time Indication: 0
Date: 2003.10.10
Time: 14:43:00
Coding: 0028196
1 Fault Found:
Freeze Frame:
Fault Priority: 2
Fault Frequency: 14
Reset counter: 120
Mileage: 245840 km
Time Indication: 0
Date: 2003.10.19
Time: 11:41:00
Revision: AV1C1010
Coding: 0000532
1 Fault Found:
Freeze Frame:
Fault Priority: 3
Fault Frequency: 69
Reset counter: 80
Mileage: 245768 km
Time Indication: 0
Date: 2003.10.08
Time: 00:01:46
Freeze Frame:
Voltage: 9.63 V
Count: 231
Coding: 0000001
1 Fault Found:
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 80
Mileage: 245800 km
Time Indication: 0
Date: 2003.10.10
Time: 14:46:50
Address 56: Radio
Cannot be reached
Cannot be reached
Cannot be reached
5 Faults Found:
Freeze Frame:
Fault Priority: 7
Fault Frequency: 18
Reset counter: 255
Mileage: 245816 km
Time Indication: 0
Date: 2003.10.11
Time: 12:39:47
Freeze Frame:
Fault Priority: 7
Fault Frequency: 18
Reset counter: 255
Mileage: 245816 km
Time Indication: 0
Date: 2003.10.11
Time: 15:30:05
Freeze Frame:
Fault Priority: 7
Fault Frequency: 18
Reset counter: 255
Mileage: 245816 km
Time Indication: 0
Date: 2003.10.11
Time: 16:25:35
Freeze Frame:
Fault Priority: 7
Fault Frequency: 18
Reset counter: 255
Mileage: 245816 km
Time Indication: 0
Date: 2003.10.11
Time: 16:26:17
Freeze Frame:
Fault Priority: 7
Fault Frequency: 2
Reset counter: 120
Mileage: 245845 km
Time Indication: 0
Date: 2003.10.20
Time: 00:46:06
Coding: 0028196
Coding: 0028196
1 Fault Found:
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 74
Mileage: 245792 km
Time Indication: 0
Date: 2003.10.10
Time: 14:43:10
Coding: 0000005
1 Fault Found:
Coding: 0001208
3 Faults Found:
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 74
Mileage: 245803 km
Time Indication: 0
Date: 2003.10.10
Time: 15:25:10
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 74
Mileage: 245803 km
Time Indication: 0
Date: 2003.10.10
Time: 15:25:10
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 74
Mileage: 245803 km
Time Indication: 0
Date: 2003.10.10
Time: 15:25:09
Indoblaze (06-29-2024)
Reaching out to the masters
Dvs_Dave.... you're awesome,thank you for the response... yes got this A8 running good just needed some help Coding modules that show incorrect coding. .... thanks a million....'
AudiWorld Wiseguy
My question is how did all this bad coding come about? What has happened to the car as this can’t happen by itself. We need an understanding of how the car got in this condition before we can help diagnose.
Would say mmi sw update , locksmith bricked immobilizer, towed to Audi local dealership unable to fix... towed it back and here we are.. got it up and running.... just was trying to get some music going...
AudiWorld Wiseguy
The vehicle thinks it’s been stolen (maybe because it has been?) so all the component protections have activated. It’s unrecoverable and at best a partial parts car.
AudiWorld Wiseguy
