Fuel system cleaner?
Does anybody here use a fuel system cleaner? I was looking at Royal Purple Fuel System Cleaner and Stabilizer. It claims to remove deposits and build-up, as well as restoring fuel economy and maximizing horsepower.
Are these claims legit ... or would I just be wasting my money? I was under the impression that because of the Audi's engine design with direct injection, the top side of the valves would not benefit from any cleaner additives.
The balance of probabilities says you are probably wasting your money on a one time application. It might do something if you were using it continuously; but, whether the continuous cost of using fuel system cleaner for 5 or 6 years is less that the cost of getting your injectors cleaned - you would need to sit down and do the arithmetic.
However, if you are using a Top Tier fuel in your car it already comes dosed with cleaners. As an exampIe I believe Chevron Mobil uses their Techron product in their premium fuel. If you go to the Top Tier website you can find a list of the fuel vendors close to you that qualify as top tier vendors. Where I live, Costco premium qualifies as Top Tier.
The following 3 users liked this post by 142 guy:
Originally Posted by 142 guy;25917703[color=#2980b9
]The balance of probabilities says you are probably wasting your money on a one time application. It might do something if you were using it continuously; but, whether the continuous cost of using fuel system cleaner for 5 or 6 years is less that the cost of getting your injectors cleaned - you would need to sit down and do the arithmetic.
However, if you are using a Top Tier fuel in your car it already comes dosed with cleaners. As an exampIe I believe Chevron Mobil uses their Techron product in their premium fuel. If you go to the Top Tier website you can find a list of the fuel vendors close to you that qualify as top tier vendors. Where I live, Costco premium qualifies as Top Tier.[/color]
All Costco gas should be approved/listed by Top Tier
https://www.costco.com/fuel-promise.html
Costco is listed as a TOP TIER™ gasoline retailer. Find out more at www.toptiergas.com.
Kirkland Signature™ Gasoline contains five times the EPA detergent requirement in both regular unleaded and premium grades, and is formulated to clean your engine and help your vehicle run like new.
I ran a can of BG 44k through my a4 shortly after I first got it, BG 44k was the most recommended product I could find, I felt like I gained some power and economy, maybe just a placebo though, I never took solid before and after tests
The following 2 users liked this post by LightRobin:
A4Audi4Fun (06-30-2024),
A4Driver (06-30-2024)
Interesting
Costco.ca says on their website that they are a Top Tier fuel vendor. The Top Tier website lists Costco as a Top Tier retailer; but, they do not include my local Costco in the Top Tier list when you search by location. There are a bunch of other listed Top Tier vendors listed in my area. Do any other Canadian owners using Costco for their fuel have this anomaly? I am wondering whether this is a problem with the Top Tier location search list or whether my local Costco is getting fuel from a non Top Tier wholesaler.
Interesting
Also fwiw, my local Costco has TopTier stickers on every pump/grade. And it does appear on a TopTier search. Costco/Kirkland is even a Brand you can use to filter the search.
