My 2018 is due for it's 6th year/60k mile service. It currently has 51k miles.
What actually needs to be done at this time?
I got a quote from my deal for ~$900 that looks like I'm only get a basic oil change and brake fluid flush.
I don't want to be cheap with maintenance but it also doesn't make sense to spend all that money on "checks".
I've seen/heard oil changes are easy enough with a pump (without having to go under the car to drain) but how different is the brake fluid flush?
Code:
CUSTOMER QUOTE
________________________________________________________________________________
OPERATION: MMENU 60,000 Service A/T at 60,000 Miles
*** 60,000 Service A/T at 60,000 Miles ***
MACMF Air Conditioner Micro Filter, r&r
MAFR Air Filter, r&r
MATFV Final Drive - Remove Baffle; Check For Leaks & Damage
MATV Transmission - Check For Leaks & Damage; Baffle Removed
MBCDC Body - Check For Damage & Corrosion; Inside & Out
MBSBH Brake System - Check Condition Of Brake Hoses
MBSP Check Thickness Of Disc Brake Pads
MBSVC Brakes - Check That Vent Caps Are Mounted On Calipers
MCBRT Check Braking During Road Test
MDHDL Door Hinge & Door Latch - Lubricate
MDSRT Check Driveshaft During Road Test
MECS Engine Cooling - Check Freeze Protection & Coolant Level
Protection To Spec 13 Fahrenheit/-25 Celsius
MECV Engine - Check For Leaks & Damage With Baffle Removed
MELC Exterior Lighting: Check All Function & Operation
MEPRT Check Engine Performance During Road Test
MFAK First Aid Kit - Check & Record Expiration Date YYYY/MM
MFEC Front End - Check Dust Seals, Ball Joints, Tie Rod Ends
MHC Horn-Check Function
MHCA Headlamps - Check Adjustment
MHRT Check Horn Check During Road Test
MICC Instrument Cluster - Check Warning & Indicator Lights
MILC Interior Lights - Check All Interior Lights & Glove Box
MILT Interior Lights - Check Trunk Light
MMPIC Multi-Point Inspection - Complete
MOFCM OEM Oil & Filter Change
MPBRT Check Hand & Foot Brake During Road Test
MPSV Steering - Check For Leaks & Damage With Baffle Removed
MREC Rear End - Check Dust Seals, Ball Joints, Tie Rod Ends
MRT Road Test
MSBCF Safety Belts - Check Function
MSRID Service Reminder Indicator Display: Reset Display
MSRT Check Steering During Road Test
MSSCF Sunroof Systems - Check Function
MTCC Check Tires Condition & Tire Tread Wear
MTCT Check Tire Inflation Pressure & Adjust If Necessary
MTDC Check And Record Tire Tread Depth
MTRSCE Tire Repair Set: Check/Record Completeness & Expire Date
MTRT Check Transmission During Road Test
MTSCC Wheel/Tires/Spare - Check Condition, Pressure
MUCCD Underbody - Check Covers For Damage & Correct Fit
MUCIFL Underbody - Check Inner Fenders Liners For Damage & Fit
MWBC Wiper Blades: Check Condition & Replace If Necessary
MWBRT Check Wheel Bearings Check During Road Test
MWRT Check Wheels During Road Test
MWTC Warning Triangle - Check If Present (If Equipped)
MWWH Windshield/Headlamp Washer System Check/Adjust/Add Fluid
NOTES: *PR-9AQ - Air Conditioner With Electronic Regulation And Ram Air
Regulation, Comfort *911-6
QTY PART NUMBER PART DESCRIPTION PART PRICE EXT PRICE
1 VW4M0-819-439-B OD. FILTER 36.42 36.42
1 VW8W0-133-843-C AIRFILTER 42.25 42.25
1 VW06L-115-562-B FILTERELEM 18.78 18.78
1 VW06L-103-801 DRAIN PLUG 11.67 11.67
54 VWG-052-167-S0 ENGINE OIL 0.99 53.46
MISC CODE MISC DESCRIPTION QUOTE MIN QUOTE MAX PRICE
SS SHOP SUPPLIES 30.00 30.00
SHM DIGITAL SERVICE FEE 1.95 1.95 1.95
LABOR $: 398.00
PARTS $: 162.58
GOG $: 0.00
MISC. $: 31.95
TAX $: 47.41
SUBTOTAL $: 639.94
OPERATION: FBS Brake Fluid Exchange A/T All
NOTES: (Incls. 4 pints fluid)
10 VWB-000-750-S0 BRAKEFLUID 4.16 41.60
SS SHOP SUPPLIES 30.00 19.90
LABOR $: 199.00
PARTS $: 41.60
GOG $: 0.00
MISC. $: 21.85
TAX $: 21.00
SUBTOTAL $: 283.45
TOTAL LABOR $: 597.00
TOTAL PARTS $: 204.18
TOTAL GOG $: 0.00
TOTAL MISC. $: 31.95
TOTAL TAX $: 66.66
ESTIMATE TOTAL $: 899.79
This is the full list I transcribed from the maintenance documents, for 60K
Automatic transmission and final drive - Check for leaks
Battery - Check for clean terminals (no corrosion), properly mounted housing and no damage; replace if necessary. Also, check the acid level of battery only if the level can be seen through the housing and fill if necessary
Cooling system - Check coolant level, add coolant if necessary, and check protection to spec -25°C
Doors - Lubricate straps, locks (all)
Drive shafts - Check boots
Dust and pollen filter - Replace filter
Exhaust system - Check for damage and leaks
Exterior Lighting - Check front and rear lights, turn signals, cornering lights, reverse lights, license plate lights, and hazard warning lights front headlights - Check adjustment
Front and rear axle/suspension components - Check dust seals on ball joints and tie rod ends; check for excessive play
Headlights - Check adjustment
Horn - Check function
Instrument cluster - Check warning and indicator lights
Interior lights - Check all interior lights, trunk lights, and glove box compartment illumination
Manual transmission and final drive - Check for leaks
On-board tool kit - Check for completeness
Panoramic sunroof systems - Check function
Plenum Chamber and water drain valves - Check for dirt
Road test - Check engine performance, clutch, manual/auto transmission, braking (including hand and foot brake), steering, wheels, wheel bearings, drive shaft, horn
Safety belts - Check clip for belt tongue and check function of all safety belts
Snow screen for air cleaner - Clean
Stone Chip Protection - Check on the rear axle/control arm for secure fit and for damage
Sunroof systems - Check function
Tire repair set - Check for completeness and renewal date (where applicable)
Underbody (including front and rear closeout panels) - Check for damage and leaks
Visual check - Check that the wheel house liners, underbody panelling and lines are correctly mounted
Visual check - Check the chassis for possible paint damage and corrosion, from the inside and outside with the doors as well as hood and trunk lids open
Air filter - Replace and clean housing
Yes, much of the cost is apparently in "checking" things. I think a basic 10K service at my dealer is $380 but just an oil and filter change was something like $180.
I extracted the actual to-do items at every mileage, leaving out the "checks". 60K is
Engine oil / Oil filter - Change oil and replace filter
Doors - Lubricate straps, locks, hinge, latch (all)
Brake fluid - Change (2 years)
Lithium grease spray takes about 10 minutes on all the hinges
Air filter is about 15 minutes
Pollen filter is a PITA to get to, but 20 minutes if you find the YouTube video and can contort your body to get to it
An Oil change is easy if you get a vacuum pump. I got the pump, oil, filter, funnel for roughly the $180 a dealer service would have cost, and now can do changes for just the $76.11 Maintenance Kit from DAP.
I figure I'll notice if the horn, headlights, sunroof, etc., aren't working, I'll survive if the First Aid Kit is out of date, I'll likely notice meaningful leaks on my driveway, and the independent that I take it to checks all of the others each 40K DSG service. To me, "checking" everything else that often isn't worth the hundreds of dollars.
Brake fluid is one thing I leave to a pro - both the risk, and just not worth the effort. The timing comes with the DSG change - I'm not overly concerned stretching it to 3 years or so.
That quote is laughable. $398 labour for an oil change? yeah right. $200 for a brake flush is fair enough assuming they're flushing the whole system.
Is your car equipped with a DSG? I assume the DSG fluid was done at the 40k service, if not then make sure you do that.
Oil change is as easy as can be, filter is on top, there's a little cap where you'd expect the dip stick to be what you can extract the old oil out of, engine will take 5.2L of oil to get up to the max line although you'll be perfectly fine with just a 5L bottle in my experience as there's always some residual in the engine.
Brake flush is also just the same as any other car, only issue can arise if you drain the system completely then you will need a scan tool to re-bleed the ABS pump. Also if you're using a pressure bleeder make sure not to over pressurise the system as there are stories of it damaging the brake booster, Maximum pressure should be written on the brake reservoir cap.
Check out the YouTube channel Mechanical Nightmare. LOL I've seen people put the wrong fluid in the wrong place. Also seen them fill the engine oil all the way to the tippy top like it was windshield washer fluid. Some people just have no mechanical ability whatsoever.
Plenty of guys try to do a basic oil change at home and drain the fluid, put 5 qts in the engine and are surprised the engine smokes and the transmission doesnt move. THEY DRAINED THE TRANSMISSION FLUID!
. https://www.youtube.com/@mechanicalnightmare/videos
thank you for the comments.
it seems like the brake fluid should be scheduled as it's not as simple as i had thought it would be.
my car was had audi care the first 5 years/50k miles so it had all the standard services - DSG fluid was replaced at 2 years ago.
No, not right. $398 was the quote labor for a 60K service. OP listed the many, many items Audi includes in this service, as did my reply. As I also noted in the reply, dealers will quote a much lower price for just an oil change. You have the choice to not have the receommnded services performed, and I have done so many times, but "398 labour for an oil change" is a significant misrepresentation.
I got a quote for just an oil change and at $200 it still seams ridiculous to me.
BMW does $200 for 3 years of oil changes.
Code:
CUSTOMER QUOTE
OPERATION: OFSGM OEM Oil & Filter Change 2.0L T/C CYMC 17/18
SS SHOP SUPPLIES 30.00 9.95
LABOR $: 99.50
PARTS $: 83.91
GOG $: 0.00
MISC. $: 11.90
TAX $: 15.63
SUBTOTAL $: 210.94
Originally Posted by JohnnyJ
Was the oil filter in the gearbox replaced as well? It is equally important to have the filter replaced as the oil.
Maybe?
Everything was under Audi care.
I think it's labeled as "plug" on the paperwork.
Part 0CK-321-439-A returns as a gearbox filter in google.
There is nothing special about the 60 thousand mile service for an A4 unless you have some deferred maintenance. That $210 price for an oil change at the dealership is probably in the correct range. Dealership labor rates where I live are $200 / hr. When I purchased my 2003 Honda Pilot the dealership offered a promotional pre paid package of 6 oil changes for a price that came out to less than $40 per change. That offer was not repeated. The days of 3 oil changes for $200 are pre pandemic history unless it is wrapped up in some other promotion.
Depending on the beverage that you buy at Starbucks, if you leave a tip you don't get change from $10. Life has changed. If you want low oil change cost do it yourself.
