View Poll Results: Will there be a future A5 allroad?
Yes definitely
![](https://www.audiworld.com/forums/images/audiworld/polls/bar2-l.gif)
![](https://www.audiworld.com/forums/images/audiworld/polls/bar2.gif)
![](https://www.audiworld.com/forums/images/audiworld/polls/bar2-r.gif)
![](https://www.audiworld.com/forums/clear.gif)
0%
Yes possible
![](https://www.audiworld.com/forums/images/audiworld/polls/bar3-l.gif)
![](https://www.audiworld.com/forums/images/audiworld/polls/bar3.gif)
![](https://www.audiworld.com/forums/images/audiworld/polls/bar3-r.gif)
50.00%
Probably not
![](https://www.audiworld.com/forums/images/audiworld/polls/bar4-l.gif)
![](https://www.audiworld.com/forums/images/audiworld/polls/bar4.gif)
![](https://www.audiworld.com/forums/images/audiworld/polls/bar4-r.gif)
50.00%
Definitely not
![](https://www.audiworld.com/forums/images/audiworld/polls/bar5-l.gif)
![](https://www.audiworld.com/forums/images/audiworld/polls/bar5.gif)
![](https://www.audiworld.com/forums/images/audiworld/polls/bar5-r.gif)
0%
Voters: 2. You may not vote on this poll
JP: 2024 A4 Allroad (8W B9)- wheel size question
Hello Audi World. I have a 2024 A4 Allroad (8W B9) and I would like to fit 19inch wheels on it. I have researched as much as I can for sizing, but I was hoping an expert on this forum could confirm or offer any advice on what I am wanting to buy.
According to various wheel size sites for the vehicle I have 19 inch wheels need to be:
8Jx19 ET32 (30-34) with tires 245/40Z R19 PCD5x112
my question is that I would like to know if the following wheels will fit?
Mak Highlands 8Jx19 ET28
someone mentioned that they will stick out about 5mm. Will this be a problem? Something I should worry about and not buy these wheels?
The factory 19" for the 8W allroad is 19x8.0 et32. The 19" you can use is whatever fits without issue. 19x8.0 et28 is a -4mm offset difference. In offset, smaller numbers are more outward on the car, larger numbers are more inward. So the wheel will be specifically 4mm more outward than factory. Which is a non issue, if you're sticking to factory tire size (245/40r19). If you're compounding the outward shift with also using wider tires like 255, maybe you have to look more closely at it. But I imagine what people have done can be found in https://www.audiworld.com/forums/a4-...iscussion-216/
rusta77 (07-01-2024)
jczech
A6 allroad (C8 Platform) Discussion
20
04-05-2024 06:28 AM
Lichaes
07-27-2023 06:37 AM
Randolph
08-01-2007 11:13 AM
