New situation with my '24 S5SB
We are experiencing a pretty nasty heatwave in my hometown, Lodi,CA. I know this isn't normal for most Audi owners, but I drive my car in manual all the time. Today my car wouldn't shift into 6th in town. Would the 108deg heat have an effect on the shifting on my car.
I never experienced that, only the reluctance to use 1st gear if not in dynamic/sport or manually shifting with the paddle. Which is a TCU tune way of saving gas I assume, but it is a good bit of the "lag" in comfort mode.
The ZF8 does have a "high temperature operation mode" where it raises the shift points and fully locks as much as possible instead of allowing slip until it cools off, but that requires the trans fluid to get close to 250 degrees F (like 120C) I believe. I don't know if it enforces those higher shift points in manual mode or not. Were your shifts a bit more "jerky / firm"? That would likely be a side effect of its desire to stay fully locked as much as possible in that case.
Otherwise, I don't know why you would not be able to upshift, unless your RPMs were not high enough.
Not shifting normally
I drove the car this morning and the transmission is working as normal. I guess the car's computer is programmed under certain extremely high temperatures to keep the engine above a certain rpm level higher than normal. Who knew?
Well it is not good to lug the engine too much at low RPM.
Nikon1 (07-03-2024)
Yeah, that would be the ZF8 TCU doing the high temperature mode thing. It requires less torque to produce a given number of watts (IE horsepower) at higher rpms, so it's actually less load on the transmission when it can keep the revs up, at least not at the extremes.
I recall some drama last summer with some tuned cars (though allegedly also affecting stock vehicles) about cylinder 6 misfires causing significant engine damage or even catastrophic failure that seemed to be tied generally to very high ambient temperatures and low-RPM lugging? Perhaps Audi has caught wind of this and decided to tweak the TCU to be a bit less willing to upshift under these conditions, that or it could be a coincidence.
Article....How To Prevent Serious Damage On A Direct-Injected, Turbocharged Audi Engine: https://www.audiworld.com/articles/h...d-audi-engine/
I don't think the issue the OP ran into was related to the LSPI ECU map timing changes at all anyway, it's a ZF thing the ZF was doing to keep itself happy, and just happened to also prevent lugging due to its behavior.
In any case, another way to help mitigate LSPI would simply to drive in S or always manually downshift before trying to pull/pass on the highway. Lugging the engine is generally bad, the only thing it is "good" for is saving a little bit of gas, but why buy an S car if you goal is to save gas?
Nikon1 (07-04-2024)
