AUDI FAULT CODE P0741 17125 100% FIX.TORQUE CONVERTER CKT PERFORMANCE OR STUCK OFF/NO
Audi Fault Code P0741-17125 100 % Fix. TORQUE CONVERTER CKT PERFORMANCE OR STUCK OFF/NO POWER TRANSFER
The Audi has become well known as a fine automobile, unfortunately the transmission continues to be a problem.
Even when overhauled, the same factory parts are installed resulting in the same problems. LEVEL 10 has developed a series of valve body & torque converter components and modifications that will correct code P0741-17125 and transmission failures.
The best part of our modifications is there is no need for a complete transmission overhaul saving thousands of dollars.
Send LEVEL 10 your valve body & torque converter and we will perform all the necessary modifications for just $1298.00, or drop off your car and we will do it with a complete transmission service for just $1998.00 Some are higher.
Most work can be performed in a 2-3 days, with a loaner car available through appointment.We also pickup your car door to door anywhere in USA. And have our experience technicians perform the upgrade.
Don't wait for the tranmissions to fail, you can save it now with just a phone call to our service department.
Contact LEVEL 10 and Feel the Power Now!
973 827 1000 info@levelten.com
LEVEL10TRANSMISSION
Pacific Northwest Discussion
10-20-2011 09:36 PM
LEVEL10TRANSMISSION
Texas Discussion
08-12-2011 03:01 AM
LEVEL10TRANSMISSION
Southwest Discussion
08-12-2011 03:00 AM
LEVEL10TRANSMISSION
Rocky Mountain Discussion
08-12-2011 02:58 AM
