VAG-COM available in Ventura area
Hi All,
I took the plunge and bought the Ross-Tech VAG Com. I'd be happy to help out and tweak your car - especially if you have an aftermarket exhaust I can hear. :-)
I'm out at the Camarillo airport most Saturdays and some week nights.
Best,
Craig
Best,
Craig
Hey Craig, I believe that voice command can be enabled on a 2012 S5 Cabriolet by doing this.... Is this something you can help me with?
1.Connect the computer to the car and fire up the VAG-COM software.
2.Select the Electronics 2 tab, then Module 5F.
3.Bring up the Long Coding Helper and change byte 16 from “01” to “00” (the last 5 digits of the entire code should be “10000” instead of “10100” when you’re done).
4.Click “Do It!”
5.Exit the software.
6.Reboot the MMI by simultaneously pressing “Setup” the **** center “joystick” button and the upper right button.
That’s it. Once the MMI is done rebooting, the voice recognition button on the steering wheel should work. Again
4.Click “Do It!”
Hey Craig I'm in need of help with my 2006 audi s4. The navigation needs to be unlocked and some other things. I got exhaust on this 4.2 v8. Please help I'll be in camarillo this weekend 9093729368 thanks. My name is Jake
Can u pm me your contact info? I wanted to see if u can help me diagnose/fix my issue. My 2013 S5 throws a ECM under hard acceleration in dynamic mode and then power becomes limp. I was able to reset it but I can’t really drive my car to higher rpms as it throw the same code on. I’m in Riverside county but dan drive there.
DeMOROlized
Canadian Discussion
01-15-2009 05:20 PM
made2last
NorCal Discussion
01-07-2009 10:51 PM
A4 NCDubs
10-09-2006 12:02 PM
