Nitrogen for tires/Equipment being installed monday
We will have a new high tech nitrogen equipment being installed at the doraville location on monday. Nitrogen keeps a constant pressure even after driving, the molecules are larger than air which prevents air leakage, you do not have to check pressure as often and there is no moisture which can cause corrosion..
Kevin
02 1.8t A4
Butler Tire Doraville
Kevin
02 1.8t A4
Even tires properly inflated lose pressure because oxygen migrates through the tire innerliner. Nitogen migrates 3-4 times slower than oxygen preserving the infaltion pressure for up to three times longer. Nitogen contains no moisture. This, combined with elimination of oxygen, reduces rust and oxidation of the wheel and innerliner. Tires also run cooler since nitogen retains less heat than oxygen. Nitogen runs 17-21 percent cooler than oxygen. Cost is 20.00 per vehicle.
Guest
Please make sure your techs are trained properly and if you have a maintenance pit in the floor it has good ventilation.
Have a nice day from your fellow safety professional.
Chris<ul><li><a href="http://www.chemsafety.gov/completed_investigations/info.cfm?ID=41">http://www.chemsafety.gov/completed_investigations/info.cfm?ID=41</a</li></ul>
rubber? You should have dryer on your shop air anyway, if you like your air tools and mounters. The only reason you need dry gas in the tire is for pressure stability when you get the things really hot. Is someone really believing this? By the way, I used to work for Firestone in IndyCar support, I know what I am talking about. What a scam...
xkahn
02-08-2018 10:43 AM
scottnybottny
09-05-2015 01:35 PM
audijim113
09-03-2015 01:22 PM
ECS Tuning-Audi
A4 (B7 Platform) Discussion
09-01-2015 09:16 AM
