2011 Audi Q7 Yellow flashing Suspension Light
Good day guys,
I have been lurking and reading everything I could find regarding the yellow suspension light flashing problem.
It only happens in in the morning when it is cold. By 10 pm the light no longer flashes and everything works 100%
I have replaced the relay under the driver's side steering column panel as one of the suggestions from the forum.
Driving the car until it is warm does not make any difference. Seems to be that ambient temperature plays a role.
Car does not loose pressure overnight- tested by placing car in jack mode and measuring night and morning with no changes in height.
If the pump is overheating surely it will be less in the cold morning than later in the warmer day.
Could the Valve block be stuck in the cold morning ? Between 4-5 Degrees in the mornings until about 9:30 am
Any help or direction will greatly appreciated !
a_very_naudi_guy
02-06-2018 03:31 PM
