A8 D3 Adaptive suspension problem both lights on
Hello everyone
I got a 2004 A8 D3 4.2 V8 Petrol. The suspension was working fine compressor, different heights etc. I had a front left level sensor fault which would give me a headlight level error. Before a changed the sensor I scanned the car and got these faults:
Address 34: Level Control Labels: 4E0-910-553.lbl
Part No SW: 4E0 910 553 F HW: 4E0 907 553 E
Component: LUFTFDR.-CDC H05 6260
Coding: 0015510
Shop #: WSC 02313 785 00200
VCID: 2645C81E91260372EE-8072
4 Faults Found:
00776 - Level Control System Sensor; Left Front (G78)
012 - Electrical Fault in Circuit - Intermittent
Freeze Frame:
Fault Status: 00101100
Fault Priority: 3
Fault Frequency: 201
Reset counter: 76
Mileage: 205486 km
Time Indication: 0
Date: 2016.11.07
Time: 19:09:43
01772 - Signal from Level Control Pressure Sensor (G291)
008 - Implausible Signal - Intermittent
Freeze Frame:
Fault Status: 00101000
Fault Priority: 3
Fault Frequency: 154
Reset counter: 76
Mileage: 213318 km
Time Indication: 0
Date: 2017.02.01
Time: 18:52:17
01400 - Suspension Level Control
002 - Lower Limit Exceeded
Freeze Frame:
Fault Status: 11100010
Fault Priority: 2
Fault Frequency: 27
Reset counter: 37
Mileage: 206390 km
Time Indication: 0
Date: 2016.11.18
Time: 06:48:23
01583 - Leak in System Detected
000 - - - Intermittent
Freeze Frame:
Fault Status: 00100000
Fault Priority: 3
Fault Frequency: 35
Reset counter: 72
Mileage: 0 km
Time Indication: 0
I changed the sensor and at the same time I was also replacing the front discs and pads. When I finished the left side i started the car to move it and the Amber suspension light on the dash was out and no headlight fault so thought i had fixed it. I then changed the right disc and pads lowered the car and noticed that is was really low at the front, started the car and both amber and green suspension lights where flashing on the dash. I ran a scan and cleared all faults. the only one that came back was the one below:
Coding: 0015510
Freeze Frame:
Fault Priority: 2
Fault Frequency: 27
Reset counter: 37
Mileage: 206390 km
Time Indication: 0
Date: 2016.11.18
Time: 06:48:23
The when selecting different modes in the MMI nothing happens, car doesn't raise up and cant hear the compressor running.
It is simply a matter of running the Suspension Level Control Calibration on VCDS after changing the level senor?
Cheers
Coding: 0015510
4 Faults Found:
Freeze Frame:
Fault Priority: 3
Reset counter: 76
Mileage: 205486 km
Time Indication: 0
Date: 2016.11.07
Time: 19:09:43
Freeze Frame:
Fault Priority: 3
Reset counter: 76
Mileage: 213318 km
Time Indication: 0
Date: 2017.02.01
Time: 18:52:17
Freeze Frame:
Fault Priority: 2
Fault Frequency: 27
Reset counter: 37
Mileage: 206390 km
Time Indication: 0
Date: 2016.11.18
Time: 06:48:23
Freeze Frame:
Fault Priority: 3
Fault Frequency: 35
Reset counter: 72
Mileage: 0 km
Time Indication: 0
Coding: 0015510
Freeze Frame:
Fault Priority: 2
Fault Frequency: 27
Reset counter: 37
Mileage: 206390 km
Time Indication: 0
Date: 2016.11.18
Time: 06:48:23
Cheers
I have checked the relay, fuse and pump and all are working.
I started the car and ran the pump for 30secs by shorting the 2 pins on the relay but the car wont lift up at the front. I also ran it for 30secs without the engine running but still didn't lift the car.
I cant hear any leaking air. If its not lifting the car up I would think it was a massive leak that i would hear. The rear of the car is sitting just fine.
Is there a way of testing the valve solenoid block? Its not coming up with any faults.
wizardofoddd
14
02-25-2019 01:33 PM
