Q7 Alignment?
Q7 Alignment?
Hey there. I have an 18 Q7 prestige, 90k miles. Just put new vredestein tires 15 months ago. 12k miles ago. Rear driver side has been 2 inches lower for at least 2 years. Upon state inspection, mech says found a broken rear spring. He replaced both rear springs and shocks. Since then the ride is nowhere near the same. Dry road it feels loose on uneven road or potholes. Now it's winter and the truck feels super loose like its sliding on snowy or icy roads even at 30 mph. I took it back to mechanic and he says must be the tires... Should I take it for an alignment somewhere else? Not sure what to do. Hubby thinks I'm nuts...I love this truck but am afraid to drive it in the weather now.
The alignment (all four wheels) affects tire wear and steering/braking dynamics and should be verified/done whenever replacing tires. A bad alignment is visible in how the edges of tire tread is wearing, and often the steering feels 'off' and the steering wheel may appear off-center as well. It won't hurt you to go get an alignment check if worried about it, and often you can get a 'check' done for free. If you rely on shops or others to verify /fill your tires, they are likely over-filled, which makes them ride 'hard'. Likewise, if the rear shocks /springs aren't the same parts your car had on it prior, it's gonna feel like garbage in comparison due to superior spring rates, and custom damping tuning of the shocks specifically to the Q7. Tires generally don't do well in snow/ice unless they are specifically designed to excel in snow/ice conditions, which requires specific design/tire compounds be used, so if they are high performance all-season tires or summers, don't expect them to be snow shoes too.
Thank you so much for the reply. Come to find out that the original shop installed the new driver side OEM spring upside down but passenger side correctly. The spring was touching the control arm, hence the rough ride. Tore up the rear tires driving for 5 months on a bad setup. New shop reinstalled the spring and a 4 wheel alignment. New tires this week's and she is all back to normal. I appreciate your insight.
Governor
A6 (C7 Platform) Discussion
12
12-04-2018 12:02 PM
jhirsch123
Wheels & Tires Discussion
03-05-2017 08:39 AM
Baloo588
07-28-2009 07:13 PM
