Shock/Strut for 05 A6 with Eibach Springs
I was thinking about the coilovers but spring rate might be too much.
So, I looked at the Koni Struts, but the FSD state
Audi 05-06 A6 FWD and Quattro - 2100 FSD kit
FSD kit must be used with stock height suspension
BUT if you just to the FSD Info page...it says it good with the Eibachs..?????
FSD Shocks
FSD/Eibach Kits
KONI's latest technology accomplishes the task that has eluded most shock makers until now - great handling + excellent ride quality:
Taut body motion control
Excellent ride quality on all road surfaces
Patented, parallel-valve design
Available for most newer cars - more coming
Pair with Eibach springs for 1-1.5" lowering
Gold metallic finish shocks
Dark metallic gray springs in kit
Less expensive than electronic systems
Drive the car you love every day.
Should this be okay then??? ANy other shocks tha would work well with the Eibach? ALso sway bars...which are recommended.
Thanks.
Mike From PureMS...what should the install cost for such a job.
I plan to go to Pomona around Feb 18...maybe you guys can do it. If not, then just curious how many hours of labor? 3?
FSD Shocks
FSD/Eibach Kits
Thanks.
DarrenFL
12-02-2000 07:42 PM
tresturbos2
07-08-2000 11:43 AM
