New A3 BT question
New A3 BT question
This question is from a client of ours who has a A3 with OEM RNS-E and OEM BT.
I have a 2006 Audi A3 with the following factory options:
Bose Stereo
Navigation
Bluetooth package
As you may be aware, Audi just updated their Bluetooth compatibility chart (10-23-06), and they have added some new phones that are tested to work with the bluetooth system.
One of the phones is the Samsung A900 (listed as fully compatible, and supporting the directory). I purchased this phone, and it paired very quickly with my factory installed bluetooth package.
Here is the problem: While I am able to make and receive calls, and have my contacts showing up in the LED display next to my speedometer, the screen on my MMI display shows the following when I hit phone on the MMI panel:
"Phone Not Installed"
I want the phone information to show on the MMI display, not just the small display next to the speedometer. Here is the specifics on the phone:
Samsung (Sprint is the carrier, location is San Francisco, CA)
S:ES.A900
Firmware: ZB12
H:A900.06a
Library Info:
OBIGO:Q04C1-1.1
MCL:5.1.23
CMSF:1.5.2.110
Here is one interesting detail; while the main display of the MMI unit will state, as indicated above, "Phone Not Installed" there is a small icon that will appear on the screen when you are dialing a call--so obviously the main screen is receiving some data, otherwise, there would be no icon appearing (icon goes away when you end the call).
How can I get ALL information to show up on the MMI screen, including my directory?
Why does it say phone not installed, when the phone info appears next to the speedometer?
Bose Stereo
Navigation
Bluetooth package
S:ES.A900
Firmware: ZB12
H:A900.06a
Library Info:
OBIGO:Q04C1-1.1
MCL:5.1.23
CMSF:1.5.2.110
What software is the RNS-E running??
The easiest way to tell is if the bottom of the Nav display has the current time. If not, then you have the old 1A disc. If your dealer will lend you a copy of the 2A disc, you can upgrade the software in the RNS-E and then use your 1A disc for the map data without having to buy a copy.
ThunderDent
Q5/SQ5 MKI (8R) Discussion
08-18-2012 05:59 PM
Rudy H
RS4 (B7 Platform) Discussion
08-29-2006 03:42 PM
