"M power this" You want to know what a collapsed spring is?
Old 03-12-2003, 07:42 PM
Lightweight-USPowah's Avatar
Default "M power this" You want to know what a collapsed spring is?
First..
Collapse = to cave or fall in or give way.. Incase you didn't know what collapse meant..
These pictures show that not only is the top coil sitting below the one below it but both coil #3s on the passenger side and drivers side are coming into contact with coil #2.. To be honest Im not sure how long this has been going on, I started to hear noises about 2 months after I installed the kit but never thought that the springs were making the noises, I figured it was the sway bar mounts..
Passenger Side
<img src="http://images2.fotki.com/v18/photos/3/30429/195016/IMG_1394copy-vi.jpg">
Drivers side
<img src="http://images2.fotki.com/v19/photos/3/30429/195016/IMG_1403copy-vi.jpg">
I haven't contacted Bilstein yet, but Im hoping when I do, they will help me out..
Old 03-12-2003, 07:51 PM
PhilMason's Avatar
I'll be interested to see what the outcome is
Old 03-12-2003, 07:52 PM
Member
gliTTch's Avatar
Default wow...that IS collapsed..
my rear H&amp;R's, the top coil is just bearly equal with the second one. do i have a problem?
Old 03-12-2003, 08:12 PM
PanTTher's Avatar
Can you post a picture or two?
Old 03-12-2003, 08:13 PM
Default This picture points out what I mean by "top coil sitting below the one below it"
<img src="http://images2.fotki.com/v19/photos/3/30429/195016/IMG_14032copy-vi.jpg">
Old 03-12-2003, 08:16 PM
Default I started hearing thunks before I saw anything..
When you hit a dip in the road at a high speed do you hear a "thunk"? the type that gives you goose bumps?
Old 03-12-2003, 08:28 PM
mcgilla's Avatar
Default here's the problem with springs that are that coilbound...
...there not so bad for the track but for street...let's say you hit a pothole at high speed the back end is going to pop up and that's not good on the TT..it's why I removed the h&amp;rs it's inherently unsafe..I know because it happened to me and i felt like i had been tombstoned...
Old 03-12-2003, 08:39 PM
Member
gliTTch's Avatar
Default i will post pictures tomorrow...
the TT is in the garage and im workin on a project...just sneakin in a AW post break. :-)
Old 03-12-2003, 08:44 PM
PanTTher's Avatar
Default You can potentially break the swing arm and damage the chassis if pot hole is big and you're going..
fast.
PanTTher's Avatar
ok, thank. Will look for it.
Quick Reply: "M power this" You want to know what a collapsed spring is?
