2001 TT/225 Alarm problem
Old 02-21-2018, 10:24 AM
  #11
vtraudt's Avatar
Any further updates or input to this problem?
Car alarm goes off erratically. Trying to remote diagnose (car not here, cannot run VAGcom currently): what are common causes for the alarm to go off for no reason?
Old 02-21-2018, 06:39 PM
  #12
Mister Bally's Avatar
Microswitch on one of the door lock mechs is bad.
Old 04-28-2020, 10:09 AM
  #13
hagakurejunkie's Avatar
Originally Posted by Rogue Wave
More to the story. After spending some time with the car, here all all of her issues: interior door lock switch does not work althought the light is on, interior motion sensor override button does not light up and the dome land map light does not turn on when the car is running - it works otherwise and alarm issue described below. Does this sound like a bad Central Control Module??
For future reference, signs of a bad CCM (comfort control module) are as follows:
Unable to use key fob to unlock vehicle or open trunk
Unable to open fuel access door with button inside cabin
Unable to open trunk using button inside cabin
No map lights/interior lights
No interior locks
TT Roadsters are NOTORIOUS for leaky rear window seals and conveniently the CCM is located directly underneath the rear window, making it prime to get hit with water and short out. If you are experiencing any of the symptoms listed above, it's the CCM. Module master will rebuild your CCM for $200. You will have to pull it though. Easiest way is to do this when you repair the top (buy a new one from Hartz for $500 and find the install wiki on the internet, I did this job last year and it took me about 20 hours working VERY part time on it. Don't buy the audi one because it sucks. The Hartz one is sewn into the top)
johnburgoyne
Events Discussion
03-01-2016 12:49 PM
johnburgoyne
New Member Welcome Area
03-01-2016 10:41 AM
chosos
02-23-2010 04:34 AM
VUDOO TT
12-07-2005 04:05 PM
bobos
02-13-2003 11:36 AM
Quick Reply: 2001 TT/225 Alarm problem
