2001 TT Complete electrical shutdown - help !
I have a 2001 TT Quattro Roadster that I've been really pleased with. However a couple of days ago the car would not start, ALL electrical components were down. I lifted the hood and tried to remove the battery cover to check it out, but before I could complete that a friend that was inside the car told me everything came back up to normal, it seemed as if there was a lose connection. On the way home, the car lost all power again, 3 times, each time for a split second. All gauges would "die" and come back up to normal, so I hardly had any safety issues.
This is really bugging me, since I later checked all connections around the battery and there's absolutely nothing lose. I haven't been driving the car, concerned that one time it might die and not come back up while driving, since I mostly do my driving on the freeway.
Any advise?
Any advise?
Any advise?
Any advise?
Particularly the fuse closest toward the pass side, bolt both nuts down with a wrench. I replaced a battery then an alternator before finding out about this on my own. Now I check the the connection every couple weeks.
Ok, so I checked all nuts and bolts, and they were pretty tight. I did see however a connector that seemed kinda lose. I removed it and tried to turn the car on, and no problem. I had the engine running and tried to remove it, and no problem, so I don't think this is either.
I'm still trying to find the time to do more research to see what the problem could be, it's really annoying knowing that all of a sudden the car will eventually just die !!
I have had a grounding issue twice..
It turned out to be a bad connection to the transmission bell housing. With me I didn't loose all power but there was 3 or 4 volt drop over that bad connection.
Sounds like a grounding problem, but cleaning all of the contacts shown in the photo above can't hurt either. I did a gounding mod on my car 4 years ago. Basically I now have 4 ground points in the engine compartment and I have had zero electrical problems since.
Well, it's taken me a while to update the status of the car, sorry about that.
I'm glad to say that the problem has been fixed. I just cleaned all connections and paid special attention to the grounding wire, which I think it was the issue. I did not go as far as adding any grounding points, but I did remove the whole battery to clean the actual grounding point beneath it.
Thanks to everyone for the help.
digixp
05-06-2013 07:55 AM
