6 speed transmission problem after warm up and engine vibration
I have a similar problem as the post below. My transmission shifts rough after the car gets warm up along with engine vibration that feels like something is loose. Does anyone else experience this?
'01 225 Quattro<ul><li><a href="https://forums.audiworld.com/tt/msgs/1638828.phtml">https://forums.audiworld.com/tt/msgs/1638828.phtml</a</li></ul>
and then I would look at the 034 Motorsport's rubber mounts.
If you have the stock dog bone mount, change out the rear rubber insert with the Energy suspension insert.
Are you guys saying that the mounts affect how the gear works? My gears are hard to engage after about 20 minutes of driving.
Your issue sounds completely unrelated to worn engine mounts, but rather something heat related in the transmission, such as transmission fluid level/condition.
That would explain the rough gear shifting. However, all this begin with engine vibration. Does this mean I have two separate problems that coincidentally started at the same time or an entirely different problem?
Pat in Mtl
07-04-2011 01:47 PM
TripleBlackS6
Audi Original "S" Cars
07-08-2005 11:48 AM
