60,000 service - How much did it cost you all?
They did a full inspection, changed the oil and filter (my oil and filter), changed the air filter, the pollen filter, rotated the tires and flushed the radiator. They lubed all the hinges and cleaned and lubed the sunroof rails. This came to $323 (not a dealer). $800 does seem a bit steep.
The take it for a 30 mins drive (BS I bet)
Air filter
Brake fluid
Clutch fluid
Engine oil
Oil filter
Spark plugs
Total Estimated Parts Cost
Labor Action Item Labor Cost
Replace Air filter
Check operation Auto shift lock/starter safety switch
Inspect Ball joints & tie rod ends
Check/service Battery
Flush/replace Brake fluid
Inspect Brake system
Flush/replace Clutch fluid
Check level Coolant
Inspect Drive axles
Change Engine oil
Inspect/adjust Exterior lights
Inspect Fluid levels
Inspect Hinges, locks & latches
Inspect Manual transmission
Replace Oil filter
Check On-board diagnosis system
Reset Service reminder light
Replace Spark plugs
Inspect & lubricate Sunroof
Check lubricant Trans final drive
Inspect Transmission
Inspect Wheels & tires, incl.spare
Check fluid level Windshield washer
Air filter
Brake fluid
Clutch fluid
Engine oil
Oil filter
Spark plugs
Replace Air filter
Check level Coolant
Inspect Drive axles
Change Engine oil
Replace Oil filter
Replace Spark plugs
You *want* to do the timingbelt at 60-70k, especially if you have a 2000 or 2001 model.
It's fairly unlikely that the timingbelt tensioners will actually last the 120k miles that the belt itself is supposed to be able to handle..
