Adjusting shift linkage ...
These are the instructions i found from the archives ...
"release the cable ends
put the transmission in the locked adjustment position
remove the screws for the shift ring
place the nail, screwdriver, or other device in the two holes to hold the shifter in the appropriate position
snap the cable ends back into place
pull the pin to unlock the transmission
remove the item holding the shifter in place
replace ring screws"
Where is the adjustment part? The part where the actual cable ends get adjusted? I replaced the clutch and the linkage is out of adjustment. Thanks.
2001 Audi TT 225 6spd
Scroll half way down on the link below...<ul><li><a href="http://www.dieselgeek.com/sigmasixinstall.htm">http://www.dieselgeek.com/sigmasixinstall.htm</a</li></ul>
<ul><li><a href="https://forums.audiworld.com/tt/msgs/1638459.phtml">https://forums.audiworld.com/tt/msgs/1638459.phtml</a</li></ul>
jhoeppel
08-24-2006 07:28 PM
quattro100
02-26-2005 04:46 PM
