Aftermarket Amplifier/Subwoofer install
So, I've seen a few hundred threads of people asking how this can be done but not a single one (that I've found in search) that has a clear answer for this and I'm going to hope this thread doesnt go the same way. I accomplished this task in my 01' a6 with full bose system, but the drastically different systems are throwing me for a BIG loop. I'm now onto my fiance's 00' tt. Here we go:
Project stats:
2000 Audi TT Coupe 1.8t 180hp -Concert Stereo w/ bose & cd changer.
Mission: Install aftermarket amplifier and sub-woofers with losing as few stock components as possible. Retain factory head unit and factory speakers.
Past Audi stereo experience:
Installed aftermarket amplifier by hard-wiring in between the factory head unit and factory amp in my 01' A6 w/ bose to power two 12" alpines. Was satisfied enough with sound for how little I spent, would love to replicate that with the tt.
What I've accomplished:
Power cable is run clear from battery to trunk, very clean run; similar enough to the A6, just a much more "cramped" install area obviously.
My big troubles:
Will be running an 1800w peak Kenwood mono-amp (1000 rms). I have no idea how to tap this thing in to get bumps that correspond with music, and yada yada. The whole turn on with stereo power thing would be fantastic. So here it is guys, I need YOUR wiring expertise.
Disclaimer:
I'm not afraid to hard-wire/solder. Would greatly prefer it by all means, anything I blow up is my sole responsibility
Thanks, and please help if you are able.
Project stats:
My big troubles:
Disclaimer:
To clarify if the original post wasn't clear enough:
I really only need help with the P-conn and RCA's. I've used this same system before so the subwoofer to amplifier wiring etc is not a problem. Simple need an idea who to connect to head unit since there are no RCA's. When I did the A6 I stripped RCA's out and hard-wired the positive/negative shields into existing wires before the amp but after the head-unit. I am far too unfamiliar with the TT stereo to start chopping and soldering without diagrams and guidance. Please help.
Jeff has a lot of great write-ups that he did on his (now late) TT.
I think this is what you're looking for. http://mk1tt.montebellopark.com/amp.html
The root directory: http://mk1tt.montebellopark.com/
FYI there are differences on all of the first 3 years of the TT with completely different versions for roadster/ coupe. Bentley manual is your best source.
Some of the coupes don't even use the rear outputs (check to see if your concert head unit has a fader control, my 2001 with Bose doesn't, so there is no wiring connected to LR or RR on the head unit). The output to the rear speakers is driven in parallel off the amp.
Mick, very good info and thanks for the diagram. I will do have to do some digging in terms of the LR/RR. I am a hair confused on what you mean by $ outputs?
That was a typo, an electrical symbol that didn't translate. Fixed revised to "with".
This is a better comparison with pin # s. The Delta has the same pin# as the concert except there is no plug IV.
You need TT Bentley manual drawing EWD74-75.
Any Luck. i have an 05 Audi TT Concert CD with CD Changer and Bose. I want to do the same amp/sub install. i have an Alpine amp with 2 10" Rockford Fosgate Amps. Were you able to find out which wire to tap into?
Please help.
Thanks
Please help.
Thanks
i just did my amp/subwoofer install with stock Concert stereo this past weekend. i took a bunch of pics. I am currently in the middle of doing a How-To write up on the whole project. It was easier than i thought. I will post it very soon.
Here is the my write up. I hope it helps. Let me know if you have any questions. Next project is getting Pac-audio harness to add AUX/Bluetooth/iPod connections to the stock head unit.
Steve19Ohio
12-11-2010 01:31 PM
Fruity Yummy Mummy
12-16-2008 08:14 AM
mrash234
12-04-2008 05:58 PM
