Airbag light is on, and codes. Do I need a new airbag, or can I fix this?
Saturday,07,July,2007,16:03:22:39069
VAG-COM Version: Release 704.1
Address 15: Airbags
Control Module Part Number: 8N0 959 655 B
Component and/or Version: Airbag Front+Seite 6000
Software Coding: 01103
Work Shop Code: WSC 01236
1 Fault Found:
01217 - Side Airbag Igniter; Driver Side (N199)
32-00 - Resistance too High
Address 15: Airbags
1 Fault Found:
sometimes moving the seat all the way forward can strain the connectors. That airbag is in the side of your seat. Clear the codes and see if it comes back. If it comes back and you are sure the connectors are solid, then you need a new airbag.
