Airbag light - Module reset - VAG COM help
Hello guys,
So my airbag light has been on since I bought my 01 audi tt coupe 1.8T awd. I decided to get VAG COM to see if I could fix the problem and i was getting the 65535 code. I try to recode the damn thing (writing down the values it had before) and as soon as I changed the numbers I got new faulty codes, even when using the values I had before
I got these:
01044 - Control Module Incorrectly Coded
35-10 - - - Intermittent
65535 - Shareware Version. To Decode all DTCs
00-10 - Please Register/Activate - Intermittent
01228 - Shareware Version. To Decode all DTCs
35-10 - Please Register/Activate - Intermittent
I decided to send the module to myairbags.com and to register my vag com
Right before installing my "fixed" module... I ran vagcom and I got like 10 codes:
10 Faults Found:
65535 - Internal Control Module Memory Error
00-10 - - - Intermittent
01228 - Airbag Cut-Off Switch for Passenger Side (E224)
01211 - Belt Tensioner Igniter; Rear Driver Side (N196)
36-10 - Open Circuit - Intermittent
01212 - Belt Tensioner Igniter; Rear Passenger Side (N197)
00588 - Airbag Igniter; Driver Side (N95)
32-10 - Resistance too High - Intermittent
00589 - Airbag Igniter 1; Passenger Side (N131)
00654 - Seat Belt Tensioner Igniter; Driver Side (N153)
00655 - Seat Belt Tensioner Igniter; Passenger Side (N154)
01217 - Side Airbag Igniter; Driver Side (N199)
Maybe because I drove the car without the module or something?
After installing the module I kept getting the same 10 fault codes and the damn ligth is still on. I CAN'T erase the error codes with vag com, they are like stuck there
Is there anyway for me to fix this crap? I dont wanna keep throwing money away by getting a new module or something if the stupid light will still be on?
Thanks in advance
I got these:
10 Faults Found:
Thanks in advance
BUMP!
Reset Airbag light anyone??
Took my seats out, didn't disconnect battery, now I'm paying the price
Is there a way or do I have to take it to the stealership? my code reader that I use for CEL didn't do the trick.
There are some cheap devices on E-bay that can supposedly clear the fault but I don't know if they work.
wisconsin_quat
12-01-2006 10:07 PM
carbonLORD
11-08-2004 06:11 AM
Scourge
11-24-2003 01:00 PM
